GT500 Gas Cap Doesn't Seal
BLAZY
Suzuki 2-Strokes: TS100 GS450S GT500A GT750
Post by BLAZY »
I'm repairing my 76 GT500 gas tank--derusting, POR-15, petcock cleanup and vacuum bypass modification, etc.
The fuel cap won't snap down flush with the filler neck, even when I apply enough pressure to "oil can" the metal on the top of the tank. The latch mechanism clicks open and shut fine, but the back of the cap sits about 1/8" above the rim of the neck when it's in the "latch" position.
I have a new cap gasket and have fitted it both sides up with no change.
Any ideas?
Re: GT500 Gas Cap Doesn't Seal
Have that problem with one of my gas caps.
The bike was rekeyed by the PO & the gas cap wasn't assembled correctly.
See pic in this thread: viewtopic.php?f=9&t=8742&p=131994&hilit ... ly#p131994
BLAZY
Post by BLAZY »
This is helpful. Thanks.
To the Batworkbench, Robin!
Is it possible to purchase a new lock set for a cap or does it have to be re-keyed or replaced with a complete new cap?
The gas cap can be disassembled, but I'm not exactly sure how. I used a gas cap off of a project bike.
The underside of my gas gap was marked up from someone having done that.
I've never seen anything that would suggest that Suzuki sold replacement lock cylinders.
