I just ran some numbers for fun and fitting an X7 short piston should add about 2 hp at the peak and lose almost as many at 3,000 -4000. The curves cross at around 5,000.
But it still peaks at very low speed 6500 - 6750 because of the small/low exhaust port. I didn't calculate the differences that the taller crown might make. There's a lot of assumptions in those calculations, but it's indicative of what to expect. The loss at the bottom end is noticeable because there isn't a lot of power to begin with.
So what we really need is to transfer Pete's GT250 race porting onto a 380 with a set of decent pipes..
Learn Me GT380s
Re: Learn Me GT380s
I guess this would be one of those perfect times to get a base line dyno run before mods and then again after to get a real world comparative figure
Re: Learn Me GT380s
Dyno is never going to happen on my T305 or T500 intake mod I imagine. You are right it is good proof but not practical for a hobbyist like me.
I shared my experience without unbiased proof, but I do believe, excited about it, and wanted to share. Given these facts, If anyone wants to try please do as low risk as possible, For example get a spare set of pistons as I did In case you are unhappy.
Here is the port info 1974 gt250 right cylinder port measurement via paper trace. so all port width measured flattened out
all similar but, it looks like GT380 has a lower intake port floor. To be sure I checked mine a few times
All measurements from top of cylinder
Exhaust:
Top 1.280”/32.5mm
Bottom 2.173”/55.19mm
Width 1.574”/39.98mm widest
Intake:
Top 2.572”/65.33mm
Bottom 3.340”/84.84mm
Width 1.574”/39.98mm across both windows
Transfer:
Top 1.667”/ 42.34mm
Bottom 2.217”/56.3mm * Tried to exclude long factory chamfering
Width` 1.260”/32mm
Exhaust:
Top 1.280”/32.5mm
Intake:
Top 2.572”/65.33mm
Transfer:
Top 1.667”/ 42.34mm
Width` 1.260”/32mm
Re: Learn Me GT380s
@Vintageman, interesting, as you say the port dimensions are pretty similar, apart from the 380 inlet floor is lower.
Also the 250 seems to have a much wider exhaust port, although the port heights are similar.
Re: Learn Me GT380s
Craig380,
I think you said you measured straight across in the cylinder. I did a paper trace then laid the paper flat. So I was thinking that is why mine shows longer.
Is that true
For a paper trace I covered just the port I wanted so I could tape it in place on the cylinder wall so it won’t move. Them just use a soft pencil.
Update: Oops I did mess up the exhaust numbers as I looked again. repeated intake
I accidently found if you take tape (I used a black duck tape like stuff) and put it in the cylinder and rub over port and top of liner with your fingers it make a perfect sharp line in glue to measure from
Exhaust:
Top 1.280”/32.5mm 1.295”/32.893mm
Width 1.574”/39.98mm 1.426”/36.22mm widest
Intake:
Top 2.572”/65.33mm
Transfer:
Top 1.667”/ 42.34mm
Width` 1.260”/32mm
Is that true
Exhaust:
Intake:
Top 2.572”/65.33mm
Transfer:
Top 1.667”/ 42.34mm
Width` 1.260”/32mm
- markush
- Country: Germany
- Suzuki 2-Strokes: GT250/380
Re: Learn Me GT380s
Hi !
I took some values, too.
Some are equal as posted above, some are different.
All my cylinder ports were in stock condition.
Bore 54,5mm, all.
all measures in mm.
width = chord (not circumferential).
Distances from cylinder top surface.
GT380B
average values of 3 cylinders. (one set of Left+Center+Right)
Outlet
width : 33,7
top : 33,4
bottom : 56,2
(heigth : 22,8)
Inlet
width: 36,8 (over all)
(center bar width : 4,5)
top : 65,5
bottom : 84,4
(heigth : 18,9)
transfers (measure for one)
width : 27,5
top : 43,4
bottom : 56,4
(heigth : 13)
GT250L/M
Shown values are averages of 4 cylinders. (two sets of Left+Right)
The range off differences between cylinders was max. 1 mm.
Outlet
width : 33
top : 32,5
bottom : 54,5
(heigth : 22)
small additional Outlets (measure for one. Lying at the same heigth/position as transfer ports)
width : 6
heigth : 12
Inlet
width: 36 (over all)
(center bar width : 3)
top : 66,8
bottom : 84,7
(heigth : 17,9)
width : 26
top : 43,3
bottom : 55,3
(heigth : 12)
Shapes of outlet ports of 250/380 are a bit different.
Bore 54,5mm, all.
all measures in mm.
GT380B
Outlet
width : 33,7
top : 33,4
bottom : 56,2
(heigth : 22,8)
Inlet
top : 65,5
bottom : 84,4
(heigth : 18,9)
width : 27,5
top : 43,4
bottom : 56,4
(heigth : 13)
GT250L/M
Outlet
width : 33
top : 32,5
bottom : 54,5
(heigth : 22)
width : 6
heigth : 12
Inlet
top : 66,8
bottom : 84,7
(heigth : 17,9)
width : 26
top : 43,3
bottom : 55,3
(heigth : 12)
