Archived Posts
Admin
Supreme UFOB
Post by Admin »
Jug, it must've been Ed you got the 380 seat from.....I've never had one.
Admin
Supreme UFOB
Post by Admin »
I use "Aircraft Paint Stripper" from the auto parts store.
Admin
Supreme UFOB
Post by Admin »
Actually it was from 550 Lane.Same as the 380. :) I guess it's been 5-6-7Years. :?
Admin
Supreme UFOB
Post by Admin »
Would it help if I posted the centerline length and width of the 250 pan? I could probably sneak by Ben's shop tomorrow and measure...
Tom
Admin
Supreme UFOB
Post by Admin »
jughead wrote:Actually it was from 550 Lane.Same as the 380. :) I guess it's been 5-6-7Years. :?
That must've been from the 72 I had briefly.
Admin
Supreme UFOB
Post by Admin »
Another place to ask is Marcel Vlaandere at http://www.suzukitandgtparts.nl. He claims to have a set of seat cover + band for a GT250 for 55 Euros.
The seat of GT250 has a different part ID from a GT380, however I don't know if the difference is at the seat pan, or in measures. I can measure my seat in the evening, if it helps.
Admin
Supreme UFOB
Post by Admin »
Okay, back at home.
I measured the size of the seat cover:
Length (from the front seam to the back seam) is 64cm (25 inches)
Width is about 27cm (10.5inches) (widest)
Width of that honey-comb decoration is 23cm (9 inches) at back and about 15cm (6 inches) in front. Length of decoration is 53 cm (21 inches).
Hope this helps.
Admin
Supreme UFOB
Post by Admin »
Thanks! I'll try to get over and measure mine... Stay tuned!
Tom
Admin
Supreme UFOB
heres one
Post by Admin »
Admin
Supreme UFOB
another
Post by Admin »
Admin
Supreme UFOB
74 GT250 Blue Paint
Post by Admin »
Anyone know a paint code for the 74 Blue GT-250s?
Tom
Admin
Supreme UFOB
Getting the motor out - 71 T500
Post by Admin »
Ok, I've got all the bits I know that I need to fix some annoying issues - I'm sure there will be more once it's apart. I've got a couple of manuals but not the factory one. My plan is to pull the engine out in the next week or two (never done this before). So, any words of wisdom or common pitfalls to be aware of to make sure I get it disconnected and out in one piece?
Many thanks, Mike
Admin
Supreme UFOB
Post by Admin »
i took mine out by myself. i would suggest getting someone to help you take it out. its a little heavier then it looks. i used ziplock bags and labeled them and put the bolts in as i took them out. and i labeled the head of the bolt so i would know if it went in from the left or right side. im no expert as ive only done One t500. im sure lots of guys here will give you more good advice!
Admin
Supreme UFOB
Post by Admin »
I found this one on a belgian site:
http://users.pandora.be/luc.aerts1/Model_op_nummer.htm
Admin
Supreme UFOB
Seat - Chrome strip replacement?
Post by Admin »
Hey all
Im STILL working on my T125, next problem.
There is a chrome strip which runs around the seat and is held on by very fine bolts which seem to be attached to the strip itself.
They are badly corroded and cannot be undone.
Are these strips available?
Is there any other way I could go with it?
Ash
