I am about ready to install the new jets on my bike, but I am getting conflicting information regarding jetting.
The stock main jets are Cyl 1 = 110, Cyl 2 = 107.5, Cyl 3 = 110 (according to my Clymer manual) pilots are 45's in all three . When I got the bike it had El Cheapo K&N style cone filters on it (can be seen in the earlier pictures of the bike in this thread). Also all the baffles were removed. It was running pretty well and had great low and top end power. It did overheat after riding about 6 mile give or take, but I think it was due to the radiator being partially blocked or a timing issue. I replaced the water pump and cleaned out all the crud and corrosion in the motor and radiator. So that problem should be eliminated. I also installed the Accent electronic ignition system so that problem should also be eliminated. Reason I am mentioning all of this is that it could have been running lean as well, which would have helped along the overheating issue.
Anyway this is the state I got it in:
1. Stock jets, (Cyl 1 = 110, Cyl 2 = 107.5, Cyl 3 = 110 and pilots 45's all round)
2. Needles on the lowest setting, (Not sure where they are in stock form but assume the needles have been lifted from stock).
3. Cone filters,
4. Baffles removed.
Now I have added the Jemco pipes and have purchased better K&N filters like these below.
The guy from Jemco suggested going 2 to 3 sizes larger than standard on the jetting. You could read that 2 ways.
1. Go from 110 to 112.5 (2.5 actual sizes up) or
2. go from 110 to 115 (2 available sizes up)
I did not think to clarify at the time I was talking to him.
Anyway I purchased 112.5's, 115's as well as 117.5's so have these sizes to play with right now. Thinking of buying 120's as well, just in case.
Questions:
1. So my first question is, do I start with the 112.5's or 115's as the first step up. I am thinking if I go to 115's and it runs poorly then I would wonder,
hhmmm would the 112.5's have been better.
2. My second question is, is there anyone else here running Jemco's who can provide information as to what works best for them and their particular setup.
3. Third question is regarding the center cylinder, since I have gone to Electronic ignition, (assuming the points are set up to retard timing on the center cylinder somewhat to avoid overheating and hence the 107.5 smaller jet size) should I not use the same size jets for all 3 cylinders?
Any help or feedback will be great.
