All right, Odin !!! It is amazing how so many head-scratchers have simple solutions. Glad to hear you've solved YOUR head scratcher.
GT550A Mint & Original
MBD Sufferer
Odin wrote:It was the plunger!
now both plugs have a tan color.
now on Wednesday when I have the chance to ride I'll see if the larger main jet solved the surging engine when I try to maintain a constant speed.
thanks again guy's I will keep you posted.
The main is the main system from 3/4 to full throttle. If your surging below that, then it's your needle position.
I was surging at 3/4 now that's gone and its happening at lower throttle. Its not quite surging tho its sort of a bucking/surging mix.
When I increased the main jet I put the needle to the stock position.
Should I raise it or lower it. I'm so close to having her run properly (after a year) I can feel it.
T200 (full restoration)
CL450 (on the go now)
T350 (sort of started)
"Even if the voices in my head aren't real, They have some pretty good ideas"
I'll try that first.
it's weird, after my ride I noticed that my gas mileage has significantly decreased, she blubbers a bit upon acceleration and the/these symptoms begin after I have been riding for a half hour or so... in other words after the engine is hot.
my manual tells me that this is a sign of being to rich.
I will raise the needle first cause as you said, "be safe" but holy cow! anything over half throttle and she preform like a champ! I can totally feel the thrill in modifying these bikes for the track
Now that you're getting the jetting "fatter", you'll notice your fuel disappearing a lot quicker, Odin. High performance strokers are not air cooled.....they're "fuel-cooled", IMO. Just be glad you're not messing with an H1 or an H2. Your wallet would know REAL "fuel" pain, for sure.
MBD Sufferer
