New member Intro
- Suzuki 2-Strokes: GSXR 750 1976 GT500
Re: New member Intro
So I have heard the diesel will help clean it up. But what do I do with all the diesel in there? Do I just turn the crank over a bunch to mix it around then, just pour it out in a few days?
- Country: us
- Suzuki 2-Strokes: GT
I did the diesel trick in my t500 last year,I filled the crankcase and spun the crank a few times a day, after a week I dumped it out and refilled and repeated, I did this several times. You may want to flush several times at the beginning to try to get as much of the crud out as possible.
ok, sounds like a plan. I will do that for a while, and see how it turns out. Thanks so much
- dorT500
Well, if you can't be talked out of not taking the engine apart
then you might check and see if the crankchamber has drain bolts. Might help a little on the flushing.
My '75 T500 does and your GT500 might. I have not seen them on all T500's.
Good Luck
Random pics off ebay...
Good Luck
_____________
______________________
- Country: England, UK
Well if your engine looks anything like the above, I'd say it is definitely not a good idea put the top end back together with a fresh set of gaskets hoping the bottom end will be ok. Having said that, I have once done it on a Dolphin 2-stroke boat engine (The customer/friend insisted against my recommendation). I removed and cleaned the pistons, stuck a new set of rings on and honed the bores by hand. It was a very rough and ready bodge job, that I was quite ashamed of. Amazingly, it went on for a few years before salt water rusted the pistons in the bore again.dorT500 wrote:Well, if you can't be talked out of not taking the engine apart![]()
Yes that is what the engine looks like. The crank and everything moves fine. There is no rust on the crank, or scarring on the pistons or anything. It just have the milky oil on one side and rusty looking oil on the other side. I have been able to get rid of a lot of the oil in the crankcase. Right now, I have it soaking in diesel. I turned crank a couple of times before I left town for the weekend, and it was looking a lot cleaner that it was before. It would get spark and everything before, but when I put the plugs into the cylinders, it would only spit out the liquid when I went to kick start it. Basically soaking the plugs. So I am hoping that once I get it cleaned and dry, that It will spark with plugs in. I would break the cases apart, but I am just afraid that it may be beyond my knowledge to put it back.
Do the diesel trick more than once and just turn the engine upside down for a day to get it all out. Run some 2 stroke oil down the conrods into the big ends and squirt some onto the small ends too. Oil the main bearings and also the bores. You'll need the air filter(s) off so you can get to tbe carbs, then with petrol with some oil in, in the cleaned out carbs, use a squirt of easy start in each. You may need the occasional extra squirt to keep it running until the smoke clears! And there will be a LOT of smoke!!! Don't rev too much until it settles down.
I used a grade hotter plugs when I did both my 550s. 3000miles on the first and 2000 so far on the second.
Don't forget it only takes one piece of grit in the wrong place to bugger up a bearing. So like Alan said, Flush thoroughly!
I am doing the diesel a few times. I put some in there, and spun the crank a couple of times on Friday, and let it sit all weekend. Spun it a couple of times this morning, and then dumped it out. it was nasty. Then put more in it, and spun it some more. I figure I would just keep doing that for a few days, until the diesel comes out cleaner than it has.
That's the way. Remember that you only get babies when you rush things.......
