XR11/73
garry55
Re: XR11/73
Post by garry55 »
anyone know which way round the ex-starter motor ring gear bush should be fitted (picture #2 in last post)?
I forgot to check if the large oil cutouts face the crank oil seal or the outer casing :oops:
Garry
Re: XR11/73
garry55 wrote: which is (still) trying to stop the front tyre from hitting the centre header pipe.......... :cry:
Just tranner help...........
Do away with the bubble though.
Re: XR11/73
garry55 wrote:anyone know which way round the ex-starter motor ring gear bush should be fitted (picture #2 in last post)?
You posted a picture of it still mounted up on page 8
Re: XR11/73
That would indeed be different :shock:
garry55
Re: XR11/73
Post by garry55 »
Suzukidave wrote:You posted a picture of it still mounted up on page 8
So I did - thanks :up:
Garry
Re: XR11/73
Gary,
There's more metal to come off that gear and I don't think you need that "spacer" if all it drives is the nylon gear. Always more grams to be pared off. :)
garry55
Re: XR11/73
Post by garry55 »
Alan H wrote: Just tranner help...........
trust you to think of that, Al :D
Garry
Re: XR11/73
Updates :?:
garry55
Re: XR11/73
Post by garry55 »
not a lot really Dave - been busy at work, readying the holiday home for the coming season and making progress with the Tesi project, so the GT750 project hasn't received much attention recently. Plus I purchased an RF900 to run around on in the summer, so had to prep that too.
Did manage to find time at work to fabricate a pair of these plates though - shouldn't be hard to guess what they are for......
no cheating now..................... :D
Garry
Re: XR11/73
Interesting .. what ya got planned with the plates bolted to the head ?
garry55
Re: XR11/73
Post by garry55 »
found time today to cut the holes for the spark plugs
and turned 2 of these alloy housings to accomodate a pair of RGV250 rubber engine mounts
when the motor is firmly mounted on the 2 rear brackets, these will be welded to the head plates like so
then the support arms will be shortened and re-attached to the frame spars
and it will then bolt up to support the motor at the front, like so.......
this will enable me to run without a cumbersome and, in my opinion, unsightly, front subframe.
time will tell................ :oops:
Garry
Re: XR11/73
Another interesting method to get the job done :up:
Re: XR11/73
Hi Garry , have you had time to get the upper mounts welded back on ?
garry55
Re: XR11/73
Post by garry55 »
not yet Dave - time is tight at the moment and I am having issues with the rear-top motor mount.
I did find time at work to make my version of a barrel puller
I also took 6 of the original head bolts
machined the dome off and drilled and tapped them to take 8mm bolts thus
so that I can dismount the motor without disturbing the cylinder head
but until I solve the rear upper mount problem, it's on hold.
Garry
garry55
Re: XR11/73
Post by garry55 »
oh yes - almost forgot - I bought it a seat unit too ! :up:
for that "TR750" look :D
note to self - cut grass......................... :)
Garry
