I have had the pictured charger for about 30 years. It has charged countless batteries in its time and still works. Now I just use it as a tender in the winter months.
This thing is very small. It measures 3 3/4 wide by 2 by 2. As you can see, the output on this relic is only 6 - 12 watts. Anybody know what this would equate to in amps?
After some online research, I find that amps = watts divided by volts.
Sooooooo 12 watts divided by 110 volts equals 0.109 amps -- about 1/10 of an amp. At 6 watts the amps are only 0.054 or about 1/20 of an amp.
Is this right?
Coyote wrote:After some online research, I find that amps = watts divided by volts.
Is this right?
The output is 12 volts, so it actually would be 6 or 12 watts divided by just the 12 volt output = 0.5 to 1 amps to the battery.
Just for info - I use a small solar cell for trickle charging - its output is up to about 80 mA, or about 1 watt at 12 V. Works fine, and its really cheap to operate !
