Fork mods
Fork mods
I've always heard good things about Race Tech emulators and I was wondering if anyone has tried Mike's XS copies.
They look like a dead copy of Race Tech's but they come in one size to suit XS650 35mm forks.
So I was thinking cheap as usual - $49 versus a whole lot more - might just work.
I bought a set not to long ago but have not fitted them to a set of forks yet. They look exactly like the Race Techs! You don't get spare springs with them however so you have to hope the provided springs do the trick. I can post pictures or dimensions if you like....
Mike's has an inexpensive steering damper and bracket too. Shame it's not Mikes T500 instead!
Jim
Jim
The 550 & 750 forks. The GT500 forks don't have a hole up the center of the damper rod and as a result the emulators wil not work with them (unless you drill and rework the stock damper rod).rngdng wrote:So those emulators should fit the Suzuki GT forks? Hmmmm.
Lane, haven't you always said the GT500 forks were subpar? Now you have a good reason to dislike them!
Jim
The good news is that Mike's cartridge emulators will probably work in a GT750 ( and maybe a 500 as well)
The bad news is that they are not a straight drop in. I'll have to design a simple adapter to allow them to fit on top of the damper rods.
They are designed to fit inside the top of a damper rod, but the 750 damper is an unusual two piece design with a peened over piece of steel partially blocking the top.
I'd like to machine into the top of the rod but suspect that might damage it's integrity and I don't fancy the idea of the top pulling off when I pull a wheelie. I'd hate to see the sliders and front wheel fall off when the front comes up.
- Suzuki 2-Strokes: 1976 GT750
I already had a good reason.....they don't work worth a damn!
Update on the fork modification to fit Cartridge emulators from Mike's XS.
Good news is that the "adapter" only has to be 1.5-1.6mm thick, so i checked all my washers and sure enough I had a couple with 24mm OD and 15mm bore. 5 minutes with a Dremmel and drum sander and they fit like a charm.
I compared them with a set of larger Race Tech emulators and they appear to be pretty much identical to the 30mm Race techs, but at one third the price. I didn't compare the spring rates or valve deflection rates, but visually, they appear to be a straight copy.
