Archived Posts
Information and stories pertaining to racing Suzuki two-strokes. Past and Present.
Admin
Supreme UFOB
Post by Admin »
Ralph, with all the cranking those pipes go through, you might want to make some sort of band to hold them close to the frame as a support. Might use hose clamps, any thing to take the load partially off the mounts. Too bad you can't support the silencers as well, that would probably help immensely. Just a thought or two for you to consider.
Admin
Supreme UFOB
Post by Admin »
Tuner,
Thanks for the suggestions. One thing I'm going to do is relace the REALLY heavy steel silencers with aluminum ones which I will get this week from TZMike. Reducing the cantilevered load by 2/3 should reduce stress on the weld joints.
Zook-e,
Where did you get the results from so quickly?
Admin
Supreme UFOB
Post by Admin »
desmocat wrote: Zook-e,
I have my ways!!!! Actually from the saveahrma board. :arrow:
Admin
Supreme UFOB
Post by Admin »
Ralph, I took your avatar picture and did some math. Those silencers weigh about 85 lbs at their extreme rear ends, figured zero weight at the pipe mount to the end of the silencer, with the weight getting higher exponentially. An aluminum silencer would drop the weight to 31 lbs, carbon fiber, 24 lbs, which isn't hard to manage.
You might try to find a way to cushion mount the silencers to the frame for now, if possible (CB400F, Triumph/BSA older 750 triples have their mufflers mounted like that), just to do two things, lighten the weight load off the end of the pipe and silencer, and dampen the movement of the metal in the stinger/silencer. That should help with the pipes cracking as well.
Just more stuff to work on.
Admin
Supreme UFOB
Post by Admin »
Ralph in action! :grin: Sandia Classic, Albuquerque, NM Saturday.......
http://www.youtube.com/watch?v=Z6j9ggwz_L0
Admin
Supreme UFOB
Post by Admin »
Tuner,
I don't understand those numbers. Is there a decimal point missing or are you calculating the bending force at the pipe/muffler junction perhaps?
Admin
Supreme UFOB
Post by Admin »
Weight in lbs at the volume output point. In other words, how much the end of the silencer weighs sticking out the foot or so past the end of the bike. The more weight, the harder it is to support, and the more problems it causes on desmo's exhaust system. THAT excessive weight, if left as is, needs to be supported separately from the chamber itself, if it isn't shortened/lightened.
Obviously, a lighter and shorter silencer would be one heck of a lot more beneficial than the one he is now burdened with.
Admin
Supreme UFOB
Barber Vintage Festival - I'll be there
Post by Admin »
Yahoo!!! I've secured transport for my T500 to the Barber Vintage Festival - I'll be there.
Let's have a roll call for who's going to be racing T500's.
Starting Off:
Ralph Spencer #798
Admin
Supreme UFOB
Post by Admin »
Make some very light silencers http://www.titaniumjoe.com/tubing.htm
Admin
Supreme UFOB
Post by Admin »
Take a look at desmo's bike, and the silencer position, WAAAAAAYYYY out there. Even the lightest silencer gets heavier exponentially as its length grows. Not only does he need some serious feather weight silencers, but to move them closer, MUCH closer to the last cone as well.
Admin
Supreme UFOB
Post by Admin »
To keep with THE RACING.......... :lol:
Ralph got that "Yammi" this time!!!!!
http://www.youtube.com/watch?v=gUJACQVpDKc
Admin
Supreme UFOB
Post by Admin »
" Ralph got that "Yammi" this time!!!!!"
That is GREAT news, good on 'ya, Ralph!
Admin
Supreme UFOB
bummed!!!
Post by Admin »
Crap, just found out about Barbers!! Im already scheduled to work out of town that wekend and wont beable to make the short trip to north Alabama!! for the festival. Arrrrgggg. I kept track of the Mid Ohio build off and problems getting folks qualified, registered and rides running. I have to be more attentive and keep track of these Vintage races!
Maybe I can help at the next one? Dofin
Admin
Supreme UFOB
Barbers
Post by Admin »
Ralph, great dedication in getting to Mid Ohio!! Crap, just found out about Barbers!! Im already scheduled to work out of town that wekend and wont beable to make the short trip to north Alabama!! for the festival. Arrrrgggg. I kept track of the Mid Ohio build off and problems getting folks qualified, registered and rides running. I have to be more attentive and keep track of these Vintage races!
Wish you lots of luck at Barbers!!! Maybe I can help at the next one? Dofin
Admin
Supreme UFOB
That Looks Like You On Page 37 of Motorcycle Classics
Post by Admin »
Desmocat:
I'm looking in my Nov/Dec '07 issue of Motorcycle Classics and that looks like you in the photo at the bottom right. The article is about Mid-Ohio. Looking good!
Tom
