GT500 - Carb Connector Orientation
Tailchaser1960
Suzuki 2-Strokes: GT500 1976
Post by Tailchaser1960 »
Hi,
Forgot to take a picture/make notes when taking the carbs apart for cleaning! Which way does number 29 (see picture below) go? There's a cut-out in it; does this line up with the hole in the top of the slide or does it go the other way round and "block" the hole off?
Jeff
Suzuki GT500 A 1976, Honda CB750 Nighthawk, Honda CBF500
badgereng
Suzuki 2-Strokes: GT500A - 1976
Re: GT500 - Carb Connector Orientation
Post by badgereng »
I’m no expert on these bikes but does the exploded view you’ve referenced give you a clue?
The throttle slide (25-26) in the image doesn’t show a cut away which would naturally be facing the rear wheel on your bike and part number 29 looks like it ‘handed’ with a slot facing the front wheel.
If I had no better info than this picture, that’s where I’d start.
karl pa
Country: us
Post by karl pa »
I installed mine covering the hole. Not sure if that is correct, but I would think it should be sealed somewhat.
76 GT185
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
