T575 Steam Triple
- garry55
Re: T575 Steam Triple
rear / upper adjustable engine mounts in place........
and with a bit of tweaking, the chain run is good, rear wheel axle, swing arm pivot and drive sprocket centres align, and my trusty spirit level says the motor is -
level
level
Garry
- Country: england
looks good garry i actually thought you'd given up with this build and concentrating with the benelli/triumph keep up the good work and keep upsetting the purists
- Country: England, UK
Nice engine mounts. Just thought you might want to turn the rectifier/regulator up the other way to avoid water being funnelled in. I know it shouldn't leak but sods law says.....
- garry55
the lower rear engine bushes - that replace the original rubber ones - and the anti-crush tube.........
and in situ..............
Garry
- garry55
Garry
Looking good @Gary55.
Do we have an estimated time to completion?
- garry55
tz375 wrote:Looking good @Gary55. Thanks
Hoping to have it completed by March 2020.
Motor being rebuilt now, bike goes in for bespoke 3-1 exhaust system fitting in January.
Just the electrics to sort meantime (new charging system etc).
Garry
- garry55
then it may need paint.......................
Garry
- garry55
today's work - drilling and filing one of the original T595 fairing / mirror support arms.
Garry
- busa1300
- Suzuki 2-Strokes: RGV RGV RGV RGV ......
Unable to see any of your previous pics, but this one shows a great looking project.garry55 wrote:
Would have never thought of that frame working so good with a GT750 engine.
After looking at the front end, I started wondering about those calipers....(Triumph/Nissin)
They look the same as TZ250 3YL/4DP which have a 83mm spacing?....are they 83mm or the typical 90mm as in GSXR
MY TWO STROKE ADDICTION
TZR250SP 3XV2...
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ23 T
RZ 350
GT 750 J....sold.....
SX-R 800
KD 80
JR 50
RZV 500 R
https://www.youtube.com/@wedgehorsepower9869/videos
TZR250SP 3XV2...
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ23 T
RZ 350
SX-R 800
KD 80
JR 50
RZV 500 R
- garry55
both modified mirror mounts fitted and my 3rd attempt at modifying a T595 nose fairing to suit..............
Garry
- garry55
under-seat bits and pieces (2T oil tank, battery, fuse box, relays, coolant expansion tank and battery charger fly-leads) all in place. Battery sits in it's own space under the 2T oil tank (see post below), which is why you can't see it.
Garry
- garry55
As I am not running the electric starter motor option for the Steam Triple motor, it means I can run a much smaller (lighter) battery.........
Triumph T595 on the left, RGV250 on the right.
There was nowhere to mount the RGV battery in the T595's battery compartment, so I purchased a VJ21 RGV250 battery box............
and set about cutting off all the mountings...........
leaving only the tabs for the securing strap to attach to. Snug fit...........
Then I drilled the floor of the T595 battery compartment to accept a pair of rubber mounts........
and here it is, bolted in place and looking lost...........
this modification allowed me to cut 1" off the top of the T595's battery compartment to allow the Aprilia RS125 2T oil tank to fit above it.
Garry
Coming on nicely.
A truly fascinating project, Garry I love to see your updates and solutions/engineering to get it developed.
