Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Fri Jan 24, 2020 2:02 pm
Post new topic Reply to topic  [ 6 posts ]
Author Message
PostPosted: Mon Sep 09, 2019 1:40 am
Offline
Country: Denmark
Bikes owned: 1968 T20 (once owned T500)
My T20 has new pistons, std. bore, running in a new (right) and a used but very fresh cylinder and by measure as new (left).
I have some top end rattle when not under load, goes away as soon as the gas comes on.
1) Wonder how much rattle there was originally and if I can and should do something about it?
2) About 120 kms into running the thing in - the noise seems to gradually decrease. The manual says 800 kms keep under 4000 rpm and up to 1600 kms keep under 5000. Did people really do that back in the day?
Rolf
Top
 Profile
PostPosted: Mon Sep 09, 2019 4:27 am
Offline
Country: United Kingdom
Bikes owned: A100 GT250 & 4t Yams!
Did you measure piston/bore clearance and ring end gap when refitting? In spec??
If yes I wouldn't be too worried if I was you...
'Yes, they all sound like that sir' :wink:
Top
 Profile
PostPosted: Thu Sep 12, 2019 3:58 pm
Offline
Bikes owned: Suz, Yam, Honda, Kaw.
my 2 cents
I do agree 60s two strokes were noisy and some 4 stroke riders back then swore some of these 2 strokes were about to blow (didn't though). It may be fin rattling noise and you maybe able to place rubber dampers in between fins on head for example.
Also the rings during this error were thick. DId you use the OEM piston for this build? Can a modern Suz 250 piston fit that has thinner rings?
You have one new cylinder and one used cylinder if I understand? which you measured as new. how did you measure...what clearance did you find curious. Did you hone cylinders? Hone can take another thou or more off very fast. If larger piston to cyl gap you should hear some slapping/rattling while idling too and frequency of sound increased with rpm. Idle is light load too
Can you tell if one side or the other rattles?
light load while riding: Is it RPM dependent? I mean you are around 5K-6K RPM and then you back off throttle to closed position to cause this noise: if so could be fuel pinging/detonation/ AFR lean, timing off.
You can pull off head and look also look into Ex or Intake port for piston scuffing. If you want a real quit engine after a brief run it, tear it down and smooth piston skirt if high spots or build up etc.
It is hard to run a small 2 stroke at low RPM for break in... no torque down there. If you rev it too high it may "break" in too fast and have those material high spot/build up causing the noise. As above take a look see and tear down on smooth things out.
Can it be that you had rust stain/stripes in the con rods eyes due to original roller bearing setting still for decades in one spot and those stain (metal decay) finally fatigued as you ran it - now you hear wrist ping rattling?
If you can see cylinder wear like on intake side about piston skirt (no hone marks left, cast liner polished and wearing you may have a sloppy big end con rod play. I think you have to pull cyl to see that side of liner
I think any of these can cause a sound you mention if I can really understand that sound solely based of you writing.
_________________
Current Bikes
Top
 Profile
PostPosted: Fri Sep 13, 2019 8:32 am
Offline
Country: Denmark
Vintageman wrote:
my 2 cents
Thank you: Wonderful collection of ideas. I'll work my way through them.
Rolf
Top
 Profile
PostPosted: Mon Nov 25, 2019 2:45 am
Offline
Country: Denmark
I will pull the top during the winter and re-measure the whole thing.
Been looking without luck: Where can I find specs for bore, ring gaps, etc?
Thx for any help! 8)
Top
 Profile
PostPosted: Sat Nov 30, 2019 11:18 pm
Offline
Back in the seventies we used to run it in to the end of the driveway then away we go.if a two stroke doesn't rattle the key is usually turned off.
_________________
CB360T
TT250 (work in progress)
Top
 Profile
Who is online
Users browsing this forum: Google [Bot] and 23 guests
Search for:
Jump to:
Suzuki2Strokes.com
