Poor Running
Re: Poor Running
Just an off the wall thought, but are both slides correct and in the same way?
It's not unusual for someone to fit slides in the wrong carbs so they face backwards, but if a PO replaced the slides, it may be that one is in backwards.
- Country: United Kingdom
- Suzuki 2-Strokes: T250 Hustler
Re: Poor Running
Hello
I started it tonight with the airbox removed and when I placed my hand over the left hand carb there was no suction compared to the right one which tried to suck my hand in.
Any ideas what would cause this?
Paul
Paul
- Country: WALES
Re: Poor Running
That could be very bad news I'm afraid. The most likely reason there is no suction is a bad crank seal which is an engine strip down. I would do a leak down test to confirm it if you can't perform this I would go to a good bike mechanic who has the equipment.
98 carb Blackbird and GT550j
Re: Poor Running
Hello
Could that be the outer seal ?
- dorT500
Re: Poor Running
As a matter of orderly troubleshooting (we have kinda skipped that),would you please address the comments from members about the throttle valves (sliders). You can use a small mirror to look at them easier now that you have the air box off. Also, there is a rod for the sliders......I've read that they can be bent and cause problems......maybe even causing the slider to detach from throttle cable?
Here is a picture how they should be ......cutaway FACING air box. Turn the throttle grip and look if they are both entering (or one not moving at all) at the same exact time
https://m.ebay.com/itm/1972-Suzuki-T250 ... 4335.l8656" onclick="window.open(this.href);return false;"
......and you are getting a healthy stream of fuel from each outlet of the fuel petcock and lines are known clear.....correct?
Good Luck
Good Luck
_____________
______________________
- Country: us
- Suzuki 2-Strokes: GT
Re: Poor Running
+1 on that.dorT500 wrote:As a matter of orderly troubleshooting (we have kinda skipped that),would you please address the comments from members about the throttle valves (sliders)
The carb slides must move together from idle to wide open throttle.
If the slides are at different positions, or incorrect, the vacuum will be at different levels.
+1 on that also.dorT500 wrote: Also, there is a rod for the sliders......I've read that they can be bent and cause problems
The idle rods bend easily and don't allow slides to drop all the way down in carb at idle, if one slide is higher than the other you will have an uneven running engine.
Your video makes me think your left carb slide is to high compared to the right slide.
You can also have trouble if carbs are over tightened, not allowing slides to move freely.
Your first post said the left cylinder was ok, right cylinder was intermittent, has the left cylinder now stopped firing?
76 GT185
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
Re: Poor Running
Hello
Both slides seem to be lifting at the same time but I swapped the carbs over tonight and when it was running I placed my hand over each carb (one at a time) and it was sucking and it nearly stalled the engine. The other night when I tried placing my hand over the intake it was on the r/h side carb that was sucking but there was nothing from the left carb I have checked the carb tops and they are not over tightened
The r/h cylinder is still getting hot while the L/h one remains cold.
Does this point more to a carburettor problem? All the carb internals have been changed using new genuine parts except for the floats which seemed in good condition so I reused them.
Appreciate the advice
Paul
Paul
- Country: england
Re: Poor Running
have you done anything off the list i advised earlier? namely, take the left crank drain plug out and see if it's full of mixture? if it is it won't run on that pot
let's get this right the cylinder with the choke carb on it is the one that's not firing? the left pot?
[1] take the drain plug out, empty if necessary, refit drain plug - tight.
[2] take the airbox off and stuff a rolled up CLEAN rag in the left carb inlet.
[3] hold throttle just open and kick her up, see if she now runs on both cylinders.
[4] don't whack the throttle open and let engine swallow the rag remove it and see if engine runs on 2 pots.
[5] if so, you're done, if not, remove left exhaust and see if it's full of mixture - it could be by now.
[6] follow ALL the good advice that everybody on here has posted for you - not just bits of it.
[7] we'll sort the little s o b eventually
ps, i've tried the rag in the carb many times, always after a rebuild. sometimes they need a little help just to get that first lung full through. after that it's first kick every time - but don't forget to remove the rag once she's running
Re: Poor Running
Hello DD
In answer to your questions
A) it is the right hand cylinder as you sit on the bike which is not running correctly the choke liver is on the L/ H carb with a rod which connects to the right carb.
B) I have taken both drain plugs out and I did get some fuel mixed with oil but I did this again last night after I have been messing about trying to get it running properly and nothing came out.
C) I have had it running about 2500 rpm and you can see on the video it is smoking from the left cylinder and making a put put sound from the right side and there is no pressure out of the end of the exhaust
D) I swapped the carbs over and both carbs are sucking through the intake but when I change them back again the L/H one is not sucking air
E) I haven't removed the left exhaust yet
Thanks for the help because I'm floundering at the moment.
Regards
Paul
Regards
Paul
- Country: england
Re: Poor Running
hmm, strange that. the left side is working, but the left carb isn't sucking air? that doesn't make sense to me
you have the early carbs with the joined chokes? do they both open and close together properly?
do you have a fuel feed to each carb, or is there a tube from the left to the right carb? if so, is it blocked or kinked enough to stop fuel getting through?
double check everything. i've had this problem with newly rebuilt engines and every time it's been the right pot that didn't run [odd that], and 90% of the time it's been the ignition circuit, points, plug, coil, condensor etc. if you emptied both crank drains and there was mixture in both, then fuel is getting through. take the spark plugs out and turn the engine over on the kickstarter whilst watching the points. when one side closes, make absolutely sure it's properly closed. same with the other side. this is something simple that we've missed i've still got a few ideas left, but try those first
- dorT500
Re: Poor Running
There is some type of communication problem going on here. Anyway, here we are, doubling back and starting where the trouble shooting should have started in the first place.....the battery(and yes, even if its brand new) , and ignition related parts.
I'm as guilty as the next guy that has not done an orderly troubleshooting procedure sometimes but overall, it is the way to save time and frustration.
Yes, he said he was getting spark at both cylinders... fat blue spark or weak yellowish spark, intermittent? We can get to a possibility that the right side carb has been distorted just a bit from uneven tightening at the flange but first we want to know that all is as it should be at least the ignition breaker points and adequate fuel flow.....both of these brought up by members early on but not addressed.
I'm doing this on my phone right now and it's kinda of a hassle doing it that way (details) but two things have been crossing my mind all along......that is the battery and the points gap adjustment at least on the rightside has slipped and the gap is down to next to nothing.
T250,T350 and T500 have been known to drop the rightside cylinder when there is a battery issue.
_____________
Running At Last
Hello
Thanks for all the advice swapped the carbs back onto their correct cylinders after swapping them to see if it made any difference I put my hand of each carb and they were sucking air well then a flame came out of the R/H carb and then the right cylinder chimed in.
Thank God For That
https://youtu.be/P-0akGpWkS4" onclick="window.open(this.href);return false;
Big thanks for all the advice
Thank God For That
- Evans Ward
Re: Poor Running
Sounds good! So what fixed the issue?
Re: Poor Running
Hello
I'm not sure whether there was something up with one of the carbs before I swapped them the R/H one was not sucking air but after putting them back onto the correct barrels they were both sucking air and then the cylinder stared firing correctly
Paul
Paul
