How to check ignition coil & correct resistance values?
GT500-2stroke
Suzuki 2-Strokes: GT100, GT500
Post by GT500-2stroke »
Hi,
What are the correct resistance values for ignition coil windings?
I am getting 0.0 Ohm on input side and ~17.8KOhm on output ( which goes to spark plugs ).
Are these values correct?
Which manual should I buy ? Where can I find this manual ?
Thanks.
GTandcbr
Country: WALES
Re: How to check ignition coil & correct resistance values?
Post by GTandcbr »
Hi
Here is a link to help you
http://www.ozebook.com/compendium/suzi/suzidata1.htm" onclick="window.open(this.href);return false;
98 carb Blackbird and GT550j
karl pa
Country: us
Post by karl pa »
You might have a hard time finding a manual, I bought one but mostly covers the T500, which is quite different on electrics.
I use http://www.oldjapanesebikes.com" onclick="window.open(this.href);return false;
76 GT185
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
See Service Bulletin GT-28: http://www.ozebook.com/compendium/techb ... 027-33.pdf
Make sure your multimeter is adjusted to the correct scale. Your secondary reading will be higher if you are including the spark plug resistor cap.
GT500-2stroke
jabcb wrote:See Service Bulletin GT-28: http://www.ozebook.com/compendium/techb ... 027-33.pdf
Absolutely correct!
When I pluged in spark plug cap, the resistance value increased and overshoot the scale on multi-meter!
That was causing me to think that the connection is lost!
Thanks a lot for your help.
I have also checked magneto coils.
And it shows resistance values which are in thousands of Ohms.
Is this expected?
What resistance values should I be getting?
Does it mean that CDI unit is the culprit now?
I have checked ignition coil, magneto coils, exiter/pulsar coil.
All of these show some resistance values.
All of these show no broken connection.
But I have not recorded resistance values and compared with expected values.
Where can I find resistance values for all of these coils?
GT500-2stroke
Will read..thanks..
