Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Sat Jul 11, 2020 10:00 pm
Post new topic Reply to topic  [ 14 posts ]
Author Message
 Post subject: How bad is this?
PostPosted: Tue May 08, 2018 7:02 pm
Offline
Suzuki 2-Strokes: GSXR 750 1976 GT500
Pulled the flywheel off, and this is what I found. How bad is it? Is there a way to fix it, or am I stuck buying a new one? Any ideas are greatly appreciated. Do I need the coil for the bike to actually run? This is for a 1976 GT 500
Top
 Profile
 Post subject: Re: How bad is this?
PostPosted: Tue May 08, 2018 8:37 pm
Offline
That looks bad. I believe those are the two battery charging coils which you will need to run lights, horn etc. I think that the third coil at 5 o'clock is the ignition coil.
Look for one on ebay or see if you can get new coils and if all else fails they can be rewound. I have had coils rewound in Australia and by Kevin Mayer in Colorado. There are probably others. It can be done.
Top
 Profile
PostPosted: Wed May 09, 2018 3:23 am
Offline
Country: england
looks like somebody screwed the rotor extractor bolts in too far :( d'oh!
_________________
Top
 Profile
PostPosted: Wed May 09, 2018 8:29 am
Offline
I'm assuming that I can't just solder the wires together, huh?
Top
 Profile
PostPosted: Wed May 09, 2018 12:55 pm
Offline
Country: england
no mate, they won't work, file them in the bin :roll: or get them rewound?
_________________
Top
 Profile
PostPosted: Wed May 09, 2018 12:56 pm
Offline
Country: England, UK
Not likely to work unless you can ensure that that each wire is insulated from those around it.
+1 on the get it rewound or find a usable replacement
Top
 Profile
PostPosted: Wed May 09, 2018 2:11 pm
Offline
Figuring out electrical problems is not my strong suit but I would think continuity and a certain resistance measured in ohms determines if a used one you might come across is bad or on it's way out. Maybe others will chime in on that. I don't know if the GT500 service manual shows how to test them. Good Luck on whatever you decide.....as you know by now, the price of those coils available from Suzuki is enough to ruin your day....maybe a few days. :(
This must be the company (Kevin Mayer) member tz375 was referring to about rewinding them.
:arrow: http://www.mayers-mc.com/services/elect ... ecialists/" onclick="window.open(this.href);return false;"
_________________
_____________
______________________
Top
 Profile
PostPosted: Thu May 10, 2018 7:42 am
Offline
Correct. Kevin wound a TZ250 stator coil for me a few years ago and did and excellent job.
Top
 Profile
PostPosted: Thu May 10, 2018 11:14 am
Offline
There is only one magneto stator listed on eBay & its got the same problem as yours.
Mine has some sort of silicon sealant repair on the CDI coils + one of the charging coils has a loose winding. Some duct tape was used on the wiring on the back side of the mounting plate.
Rats!
_________________
GT550 72 project & 75
T500 73 project
T350 69, 71 & 72 project
T250 72
Top
 Profile
PostPosted: Thu May 10, 2018 2:35 pm
Offline
If you want hours of fiddly fun, you could rewind them yourself quite cheaply. Get the right gauge winding wire, count the number of old windings and make sure you wind new wire on neatly, tightly and carefully with the same amount of turns. Don't forget to scrape off the varnish from the ends when you solder them.
Sounds simple, but can be quite time-consuming and tricky.
Top
 Profile
PostPosted: Fri May 11, 2018 11:14 am
Offline
I am really getting curious now how much it would cost for each coil. Seems like it would only take a few minutes each, after set up, if the same size wire is used throughout each coil winding and with the machines I have been seeing.
Here is another company, in Australia.
https://www.smallcoilrewinds.com.au/ind ... ng-service" onclick="window.open(this.href);return false;
50 Edols Street, Geelong North, Victoria 3215, Australia.
Phone:- +61 3 5278 8454
Email:- enquiry@smallcoilrewinds.com.au
_________________
_____________
Top
 Profile
PostPosted: Fri May 11, 2018 2:46 pm
Offline
The reels of winding cable I have last for years unless you do a lot of rewinds. But rewinding without the benefit of machinery is a pain in the bum. The problem is to get the windings tight enough by hand and then wrapping or glueing them in place so they don't spring back as soon as you let go.
I'm sure there are proper ways to do this, but I've never been shown how to do it without fingers slipping and several expletives uttered every few minutes or so. Please note, I do not claim to be an expert at this!
Last time I did it I made up a little tool to help from plywood that worked a little like a reel to reel tape player. the rotator shafts need to be a tight fit to keep the tension. You also need a couple of marks on the winding shaft so you can count how many turns you have done as it rotates.
I suggest you don't attempt to use a cordless drill to rotate it, as it is too fast. Use a hand crank instead.
Top
 Profile
PostPosted: Fri May 11, 2018 3:14 pm
Offline
I was just curious how much the companies above would charge member jojob to rewind all those coils for him. It may be surprisingly less than expected. If I were him I would contact that company in Australia and the other one......compare prices, consider shipping costs.....it's bound to be a lot less than $300-$400US for four or five coils from Suzuki.
_________________
_____________
Top
 Profile
PostPosted: Fri May 11, 2018 5:22 pm
Offline
Ignition alternator coil is available from Rex's by the look of it, I'd enquire with them re lighting/charging coils too.
http://www.rexs-speedshop.com/epages/es ... Stators%22
Top
 Profile WWW
Who is online
Users browsing this forum: No registered users and 12 guests
Jump to:
Suzuki2Strokes.com
