Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Tue Jul 14, 2020 6:39 pm
Post new topic Reply to topic  [ 10 posts ]
Author Message
PostPosted: Thu Apr 19, 2018 2:56 pm
Offline
Questions are for the 1972 GT550 cafe build.
The crankcase has the early-style press fit SRIS fittings. Any tip on how to install them?
A pic of how Suzuki originally routed the SRIS lines on the underside of the crankcase would be useful.
_________________
GT550 72 project & 75
T500 73 project
T350 69, 71 & 72 project
T250 72
Top
 Profile
PostPosted: Fri Apr 20, 2018 8:21 am
Offline
Country: United States
Suzuki 2-Strokes: '74 GT380
Here's a pic from my '74 GT380. Not sure if the GT550 is the same or not.
Mitch
https://goo.gl/photos/YnVDs1cjtuAbvtJ86" onclick="window.open(this.href);return false;
Top
 Profile
PostPosted: Sat Apr 21, 2018 1:36 am
Offline
Thanks. I think the GT550 routing will be a bit different because of the starter motor.
_________________
T500 73 project
T250 72
Top
 Profile
PostPosted: Sat Apr 21, 2018 8:43 am
Offline
Found a GT550 build topic with a useful pic. http://www.suzuki2strokes.com/forum/viewtopic.php?t=5351&start=15
Any tips on how to install the early-style press fit SRIS fittings?
_________________
T500 73 project
T250 72
Top
 Profile
PostPosted: Sat Apr 21, 2018 1:21 pm
Offline
Country: WALES
Hi
I have a 550 J but it has the screw in SRIS valves and i have no experience of the push fit ones.
However there is a Suzuki bulletin GT18 which has some info and diagrams that may help.
_________________
98 carb Blackbird and GT550j
Top
 Profile
PostPosted: Wed Apr 25, 2018 4:33 am
Offline
SRIS was an unnecessary experiment which really didn't do very much. I take them out.
_________________
Top
 Profile
PostPosted: Wed Apr 25, 2018 7:05 am
Offline
Later GT380s didn’t have SRIS. Suzuki used bolts + washers to replace the crankcase SRIS fittings. So I got rid of the SRIS on the GT380 cafe build.
But my early GT550 has press-fit SRIS fittings so I can’t use the bolts. So I’m going to keep SRIS.
Perhaps a plus for SRIS might be that if the oiling is a little uneven with a cylinder not getting as much as the other, the SRIS might act to even it out a bit.
My current thought is that I should put the SRIS fittings in the freeze for a while.
Might also be advisable to put them in first in case I break one & have to replace it.
_________________
T500 73 project
T250 72
Top
 Profile
PostPosted: Wed Apr 25, 2018 8:32 am
Offline
I seem to recall that they are a taper fit, so it should be possible to clean teh hole, smear on a little loctite and ring them in - or give them a light tap.
On the only 72 GT550 I have worked on, we drilled and tapped the holes and plugged them - the same way we plug GT750 SRIS holes. If you go that way, don't forget to plug the barrels too..
Top
 Profile
PostPosted: Fri Apr 27, 2018 4:08 am
Offline
The ones on my cylinders were press-fit. A tap and set screw with lock-tite fixed that.....
_________________
Top
 Profile
PostPosted: Wed Apr 10, 2019 6:06 am
Offline
How time flies, or more accurately how slow we work on our builds. A year ago I asked about the SRIS and am now ready to install the lines.
Any suggestions on how to install the little clips that secure the SRIS lines?
_________________
T500 73 project
T250 72
Top
 Profile
Who is online
Users browsing this forum: No registered users and 16 guests
Jump to:
Suzuki2Strokes.com
