T500J New to the board
sbaugz
Re: T500J New to the board
Post by sbaugz »
geck0 wrote:https://www.ebay.com/itm/Suzuki-T500-Sh ... 3S&vxp=mtr
Not sure what your plan is.. Your bike does look nice and these Paul Miller tanks are top quality.
.....but then you would have to deal with Paul Miller.
1T500closertodivorce
Suzuki 2-Strokes: 197? GT 250, 2000 GSXR 600, 1972 T500J
Post by 1T500closertodivorce »
This should work..
https://www.youtube.com/watch?v=aT74wZRyU6A" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
ConnerVT
Post by ConnerVT »
Torch. Gas tank. What could go wrong?
dorT500
Post by dorT500 »
Fire....oil canning....distortion...Oohhh My. :shock:
That fuel tank you have, from what we have seen of the outside, is in very good shape. That makes it rare and valuable and entitled to a little extra labor.
I suggest at least trying the chemical route .....it's just a polyester base filler....plastic. If it gets down to where you can't completely clean out the threads (and how many people have a metric thread chaser that small?) pay a gunsmith a few bucks to do it. If he happens to own a motorcycle, he would probably do it for free. :wink:
Your call of course. Get these little details out of the way and you can move on to the 'Main Event'. :arrow:
Good Luck on whatever you decide.
_____________
______________________
geck0
Suzuki 2-Strokes: T500's
Post by geck0 »
I agree that you should try to open the badge holes Try heating a pick with a torch and work the holes Heat should break the bond Im not sure if the thread is #3 or #4 mm
T500R (Stock)
T500J (Next Stock Project)
T500? (Cafe project 34.6%)
dorT500
Post by dorT500 »
When the time comes that you want install new trim to the fuel tank, here is where I bought mine. I bought 8 feet total. The additional four feet was in case I screwed something up. :wink:
:arrow: https://www.ebay.com/itm/CCG-UNIVERSAL- ... rI&vxp=mtr" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;"
Image Here temporarily installed on my unfinished and not clearcoated yet tank. Image
I did have to cut just a bit of a notch in the back of the trim to better clear the front hold down tab on both sides to butt it tight to the tank. If you decide to get it, just dry fit first before you start cutting for length....you'll see what I mean around the front tabs.
_____________
Thanks for that info. As you can imagine, I am a little ways away yet. At the moment I am looking for a local source for the heaviest duty paint-stripper I can find. Then I will start the process and see how it goes.
In the meantime I am doing a bit more work on getting the engine stripped.
Cheers.
Heads, pistons and bores look to be in good shape.
sportston
Country: England, UK
Post by sportston »
Looks good. Did you put the cooling holes in the heads?
My head has holes like that too.
Just wondering what the countersunk screw is supposed to be doing. Is that in the cci port?
No, that's the way the heads came.
The screws and bolts I put in to keep junk out of the ports.
Anyone have a trick for rotating the piston circlips so I have enough to pry or get hold of with pliers? I got one piston off no problem, the circlip was easy to access in the gap at the top of the piston. I am having a hard time getting purchase on the circlip on the piston on the other side. Unlike the first side, not much,if any of the circlip is showing at the gap in the piston. I have tried pushing it round further but no luck so far. Just try harder? :oops:
Evans Ward
Suzuki 2-Strokes: 76 GT750, 72 H2 750, 84 RZ350
Post by Evans Ward »
A hook and pick set works well for me removing piston circlip. I use a small flathead screwdriver to seat them upon installation after getting one side started with my finger.
OK, thanks for that. I have some picks that are a bit on the flimsy side. I will try grinding the tip down on one, so it is a bit sturdier, hopefully that will get a result. Cheers.
sportston
Post by sportston »
I just use a small screwdriver
Result!
dorT500
Post by dorT500 »
1T500closertodivorce wrote:Result!
:) 'Man of few words usually has wife that has many words'. :D
_____________
