What crazy things have you seen done with your model Suzuki?
dollydog
Country: england
Re: What crazy things have you seen done with your model Suz
Post by dollydog »
yip :D and still got it :D the first and only time i've made a seat from scratch. made the base - 6mm aluminium - cut the foam, made the seat cover and fitted it. NEVER AGAIN! i used to be an upholsterer years ago - but i made divan beds :D
sportston
Country: England, UK
Post by sportston »
dollydog wrote:yip :D and still got it :D the first and only time i've made a seat from scratch. made the base - 6mm aluminium - cut the foam, made the seat cover and fitted it. NEVER AGAIN! i used to be an upholsterer years ago - but i made divan beds :D
You have my complete sympathy. I have spent more time trying to make a seat and base from scratch than any other job on my resto so far. Its a nightmare to do well. :( I too have vowed never to do it again. Next time I will give it to someone else to do. :?
dollydog
Country: england
Post by dollydog »
let the ts250 rebuild begin :D
dollydog
Country: england
Post by dollydog »
first fix :D engine rebuilt with all new bearings, seals and gaskets. converted the rm250 kickstart to fit the ts250, so now it's time to start fabbing the exhaust :D
This is my other T500......the baby, only had this one 39 years !
It's a bit of a work in progress really, a little bit thrown together to get to last year's TT. I want the extra frame bracing, and an exhaust system like my Alpina 500.
....and just for fun, my 74 Kettle. Recently acquired a Piper 3-1, so I may just fit that for the heavenly sounds !
smokin_blue
Country: usa
Post by smokin_blue »
This was my first custom I built while at university. It is a '74 GT250 with a T350 top end bolted down. I had to over bore it at 1.5mm over so it calculates out to a GTT333 I wanted to just call it L/3.
The extra cc's it had over the original 250 really helped the torque department.
'07 Suzuki SV650
'90 GSX-R1100 streetfighter
'72 T500 with a Lyster frame
'69 T500-parts/project?
'83 GR650-project
Past bikes
'06 Triumph Sprint ST
'86 GSX-R750
'74 GT250/T350 custom
'79 GS750
'74 TS250
'81 TS100
dollydog
Country: england
Post by dollydog »
first fit, homemade exhaust system. pretty close for a first go :D
What was that pipe off originally? Looks almost like an RG250 pipe but it's probably larger.
dollydog
Country: england
Post by dollydog »
spot on :D
cut it at the first baffle cone. welded a shortened 60mm - 48mm reducer [o.d.] and made the rest up to the exhaust port :D
tried an rgv to start with, but it was too oval for me to work with. tail pipe off the rgv though :D
dollydog
Country: england
Post by dollydog »
2nd fit and much better :D time to start getting the forks in order. rg250 fork legs, gt550 yokes milled out to 36mm and gt250 front wheel with twin discs. i've got the brake calipers, just need some discs the right size :D
It may just be the photo, but it looks like there's a huge step between the header and chamber. Might be an idea to replace the horizontal section with a cone to eliminate the step. The chances of all teh tapers and lengths being ideal are unlikely, but a step will probably hurt performance.
What are you planning on doing for a side or center stand?
dollydog
Country: england
Post by dollydog »
hi tz, somebody else said that, but in reality it's just the angle i took the photo at :D i'll try and explain. the header pipe is 48mm o.d. the first baffle cone is 60mm o.d. to join them i've got a 60mm to 48mm reducer, very short, but it gently tapers about 10mm in length from one o.d. to the other, so i was hoping that would be enough? suppose only time will tell. until i get my milled out fork yokes back i can't put the front end together and try the engine - only then will i know if it's worked :D
hi jab, the centrestand is fitted already. if i had some help and someone to lift the back end for me, i could release the centrestand and see how it sits in its 'relaxed' state :D unfortunately, i'm on my own, so until the front end is on i can't release it. bike is finely balanced at the minute. don't know whether you can see it in this photo? but there's a gt250 swingarm hanging on the front end to keep it down for now. oh, for an apprentice :D keep the comments coming, i'll try and answer or argue against them asap :D
If you are interested in a side stand, it might be possible to come up with one that won’t cause a cornering clearance problem.
I have a GT380 mix-and-match build and was able to solve the cornering clearance problem.
For what I did see: viewtopic.php?f=21&t=13036
