GT750/GT550/T500 bronze swingarm bushing options
Getting your chassis to handle your blazingly fast Suzuki powerplant.
There are some old posts about the PartsNMore bronze swingarm bushing not fitting. The ID is OK, but the OD is too big.
viewtopic.php?p=98233
http://www.partsnmore.com/parts/suzuki/ ... y]=chassis
OldBikeBarn also sells them:
http://www.oldbikebarn.com/suzuki-72-77 ... g-set.html
As does DiabloCycle:
http://www.diablocycle.com/Suzuki-Swing ... ronze.html
Does anyone know if any of these options currently fit without modification?
sportston
Country: England, UK
Re: GT750/GT550/T500 bronze swingarm bushing options
Post by sportston »
No idea, but i would be interested to know as I might need to convert mine one day
HVCcycle sells bronze bushings for Yamahas & Kawasakis, but not Suzuki.
They have a warning: “The Bushings must be pressed into the swingarm. If the Bushings are struck with a hammer or pounded in the Bushings will be damaged”
That might be the issue with the Suzuki bushings I found — they might need pressed in.
I ordered the stock Suzuki bushings & will use those unless I have a solution for bronze bushings that don’t need pressed in.
Found a bit more info from the OldJapaneseBikes website: http://www.oldjapanesebikes.com/1973_GT750/page-3
Properly sized bronze bushings are available from The Kettle Club in the UK & Reiner in Germany.
http://www.thekettleclub.com/regalia/
email: GTReiner1@aol.com
Suzuki switched to needle roller bearings on the GS bikes.
A conversion for the two strokes is described here: http://www.pinkpossum.com/GT750/phattra ... winger.htm
Per an old forum post, Pedro used to sell phosphor bronze bushings that he made himself.
viewtopic.php?f=7&t=512&p=110446&hilit= ... ze#p110446
