Mixing 2T oils?
grumps
Suzuki 2-Strokes: GT 380, 1977 (now sold)
Mixing 2T oils?
Post by grumps »
Hi all,
In my recently acquired GT380 is a gold coloured oil in the CCI tank. My local restorer suggests it's probably just normal engine oil POs have been using instead of 2T oil (he says nearly all 2T oils are red??)
The suggestion is to run the oil really low then top up with a proper 2T oil.
If (If) it is normal engine oil then the chances are that it's at least a semi synthetic. If I then top up with a semi 2T oil all should be good - right??
I'm not good enough with this engine yet to want to drain the system and re-prime.
Does anyone use ordinary engine oil as a 2T?
Hoping this doesn't come across as a dumb question but my last 2T engine was 46 years ago and that was pre-mix.
BTW - the more I get to know the 380 the more I like it - reminds me of my youth - when I had no money to buy one.
All the best
David
If money can't buy happiness - explain motorcycles and beer!
Zunspec4
Re: Mixing 2T oils?
Post by Zunspec4 »
Hello David,
2-st oils come in a variety of colours. The Castrol A747 I use for racing is gold in colour for instance. The colour is just a dye added to the mix and I have seen oils in Red/Purple/Green/Gold colours. I would not run a 4-st oil as the engine oil in a 2-st if I could help. It should be relatively easy to drain the oil tank at the tank end, leaving the lines undisturbed. You will only then have to empty the lines and not the whole tank.
grumps
Re: Mixing 2T oils?
Post by grumps »
Thanks Geoff
I have a vacuum brake bleeder pump that I might use down the filler of the tank, pump out as much oil as I can and then top up with 2T oil, run the bike until I can see the new oil in the pipes and all should be good. (I hope!)
GTandcbr
Country: WALES
Re: Mixing 2T oils?
Post by GTandcbr »
IMHO i would drain the tank and flush the oil feed pipes too. https://youtu.be/necW4LnXBHM" onclick="window.open(this.href);return false;
You have no idea what is contained in the oil tank it could be contaminated with anything. Just a heads up you cant mix mineral oil with synthetic as this causes the oil to 'gloop' which is similar to clotting. This is just my opinion its your bike and your choice.
98 carb Blackbird and GT550j
grumps
Re: Mixing 2T oils?
Post by grumps »
Hhhmmm.? The PO was well into his 2 strokes but he didn't ride the bike much and only had it a few weeks so probably didn't put an oil in
The PO to him had it 5 years......(brain wave) I have his details so I might well ask. The stuff in there could well be pukka.
Don't you just love bikes? Thanks for the link.
joolstacho
Re: Mixing 2T oils?
Post by joolstacho »
GTandcbr wrote:IMHO i would drain the tank and flush the oil feed pipes too. https://youtu.be/necW4LnXBHM" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
+1 - Drain and change.
Why risk it, your whole engine is at stake just for the sake of a few bucks for fresh 2T oil.
sportston
Country: England, UK
Re: Mixing 2T oils?
Post by sportston »
When I was at the young and stupid age of 16 I seized a 2-stroke while running on 4-stroke oil. Its not worth the risk, especially when an engine rebuild costs so much on a triple.
grumps
Re: Mixing 2T oils?
Post by grumps »
I agree lads. I'll purge it and be done with it. Thanks
sportston
Re: Mixing 2T oils?
Post by sportston »
grumps wrote:I agree lads. I'll purge it and be done with it. Thanks
A wise decision. Losing a few bucks worth of oil is a lot cheaper than an engine rebuild.
grumps
Re: Mixing 2T oils?
Post by grumps »
To be fair I don't think either of the previous POs would skimp on oil but, hey-ho, not worth the small risk.
grumps
Re: Mixing 2T oils?
Post by grumps »
Is it easy to remove the oil pump without taking things like the carbs off too? It looks a bit congested around that area.
grumps
Re: Mixing 2T oils?
Post by grumps »
Panic over I hope.
I managed to speak to the owner before last (last one only had it 3 weeks) who is a very nice guy and really helpful - and reassuring about the bike itself.
Oil is Silkolene Scoot 2 Semi-synthetic so I'll carry on with that for a while.
Thanks for all the posts lads, I really appreciate them.
David
GTandcbr
Country: WALES
Re: Mixing 2T oils?
Post by GTandcbr »
Great news save you some time but just one more bit of advice. Your local restorer who told you "The suggestion is to run the oil really low top up with a proper 2T oil" hasnt a clue about 2 strokes!
grumps
Re: Mixing 2T oils?
Post by grumps »
Thanks GT - future words of advice from him will be taken with a pinch of salt!
grumps
Re: Mixing 2T oils?
Post by grumps »
So if two 2T oils are both JASO FC / API TC, are they basically the same and equally competent? Both semi synthetic 2T oils.
The Scoot2 is described as for scooters, mopeds and minibike engines. Any good for a GT380 engine?
Sorry about the questions - I'll get there eventually !!
