Upgrading your rear axle nut.
- Suzsmokeyallan
A post with photo I created over at the KC site.
http://www.kettleclinic.co.uk/kcforum/v ... 14&t=10240" onclick="window.open(this.href);return false;
- Mgmark
- Suzuki 2-Strokes: ‘75 GT750, '19 Triumph T100
Re: Upgrading your rear axle nut.
Nice! I like this kind of mod that cleans up the bike and simplifies service work.
Do you have a supplier in the US?
Mark
Mark
- Suzsmokeyallan
Easy enough, order the rear axle nut and the tool kit box wrench (27mm) for the 1993 Honda CBR900RR. Both items should cost you under $20.00
- Suzsmokeyallan
To answer a question Evans Ward posed, cut the rear axle through the split pin holes then grind the end flush so the hole remnants just disappear. Also grind a slight taper around the edge so the threads are not sharp.
- Evans Ward
- Country: England, UK
Cool mod. Do you know if the thread is the same on the gt380?
- Suzsmokeyallan
I believe the 380 axle is a smaller diameter.
Ah I see. I shall have to do some homework to find out what smaller modern bike shares the same thread as the GT380.Suzsmokeyallan wrote:I believe the 380 axle is a smaller diameter.
- Suzsmokeyallan
Possibly one from an Early CBR600, you need to look around for the fujilock flange nut that will fit. Have a look at Kawasaki as well.
The GT550 & GT380 both use real axle nut with part # 09141-16001.
- Mgmark
Here is the Honda part number for the nut.Suzsmokeyallan wrote:Easy enough, order the rear axle nut and the tool kit box wrench (27mm) for the 1993 Honda CBR900RR. Both items should cost you under $20.00
90305-MB4-003
This mod does make it easier to pull the rear wheel assy. Nice!
Thanks Allan
