Suzuki TDRGV 250
- garry55
Suzuki TDRGV 250
well Suzuki never built one, so I thought, why not?
Having spent a long time looking for a suitable donor bike, I snapped up this ebay bargain.........
........a 2005 Suzuki RMZ250 motocrosser, complete bar it's (4-stroke) motor. Once home, I stripped it down and proceeded to sell-off all the parts that I don't need (most of the bike, actually!) For this project I only need the frame, swing arm, shock and linkages and the front forks. So the wheels (with Talon hubs), the carb and other sundry items have found new homes, which has helped to recoup almost all of the purchase price of the rolling chassis.
My original intention was to fit a parallel-twin motor from an RG250, so as to mimick the original TDR250, but knowing how crap these motors are, I decided to use one of the RGV250 motors I have in stock.
I want the bike to run 17" wheels front and rear so I have a good choice of tyres, and lurking in the corner of the garage are these..........
........a pair of NK42A Goose wheels that I originally purchased for my GT750 track bike. Single front disc fits the brief (and the forks too, although the spindle is a lot smaller in diameter than the RMZ spindle) but some top-hat bushes in the fork leg bottoms will sort that. The rear wheel will require similar bushes for the RMZ wheel adjusters, and needs metal removing from the cush drive to allow the wheel to centralize in the swing arm.
First job was to decide how to fit the RGV motor into the RMZ frame. And this is how to do it........
.......The whole engine cradle unbolts to allow easy removal of the motor (not that it will be necessary - it's a Suzuki)
Garry
Re: Suzuki TDRGV 250
Wow, top project Garry It will make for a hairy beast when it's finished
Another excellent project. All straightforward as usual, eh Garry!
- busa1300
- Suzuki 2-Strokes: RGV RGV RGV RGV ......
This is a far out idea, and looks like the best idea yet for a Suzuki supermoto...!!!!
But then again....I love anything RGV
MY TWO STROKE ADDICTION
TZR250SP 3XV2...
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ23 T
RZ 350
GT 750 J....sold.....
SX-R 800
KD 80
JR 50
RZV 500 R
https://www.youtube.com/@wedgehorsepower9869/videos
TZR250SP 3XV2...
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ23 T
RZ 350
SX-R 800
KD 80
JR 50
RZV 500 R
I really like how you think about something and go for it too bad we arnt neighbors
- garry55
it is Dave - if we were, you could finish them all for me !Suzukidave wrote: too bad we arnt neighbors
Garry
- garry55
the rear wheel is in...........
had to machine 9mm off the sprocket mountings, recess the outer bearing 4mm, remove the rear caliper locating lug and drill the arm for a peg to be welded in to replace it.
Good news is that it is all in line now, and although the sprocket does run very close to the swing arm, I am having a 1-off rear sprocket made that will allow me to use counter-sunk bolts to secure the sprocket to the cush drive.
Front wheel next................
Garry
- garry55
trying to maintain a "factory built" standard, I took a punt on some DRZ-400SM parts on everyone's favourite auction site.
To my surprise, the headlamp brackets were the correct diameter to fit the RMZ forks, but are a bit short in length between the triple trees...........
the DRZ headlamp unit bolted straight in..........
and the fairing likewise..........
I'll lengthen the brackets so as they fit snugly between the trees, then good to go
Garry
- Country: england
why is it garry, every time i think up a project you come up with something better?
my ts250 vic camp replica is looking very mild now
bet if we got our heads together we could REALLY come up with something outrageous
- garry55
it's no better, and hopefully no worse, than any of your projects.
we just have a different train of thought to each other.
I enjoy putting motors in frames they weren't designed for
Garry
- garry55
rolling, rolling, rolling..................
next time you see it, the front wheel will have been fitted the other way round so the spoke patterns match..........
Garry
- busa1300
Progress looks good.
Whats the plan for chambers on it...run them up high like a TDR, or low like a RGV?
TZR250SP 3XV2...
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ23 T
RZ 350
SX-R 800
KD 80
JR 50
RZV 500 R
TZR250SP 3XV2...
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ23 T
RZ 350
SX-R 800
KD 80
JR 50
RZV 500 R
- garry55
looking at 1 up / 1 down - right side chamber up and over, left side low. But subject to change of mind.
Garry
- Jimroid
That thing is going to be a turd. KIDDING! Cool project!!!!! Keep up the genius work.
