A Katana................in here................?????
- garry55
Re: A Katana................in here................?????
thanks for the info guys - most helpful
I'll be back with more questions real soon.............
Garry
- garry55
got a call today to say the rear footrest mount modifications were complete, so off I went to collect the frame. The rear footrest and silencer mount have been removed, saving at least 10kgs of weight, and the front footrest mount triangulated so............
much neater - much lighter.
Back home in the garage, I fitted the front and rear ends then test-fitted a spare motor to see if all the newly attached engine mounts lined up................
they did - perfectly Just the upper rear mounts to make now I can get the exact measurements for them.
Left-side footrest mount.........
sits just right and well away from the rear shock line - result
and the exhaust ports.............
clear of the frame tubes - just as Suzuki designed them to be.
Garry
- garry55
I am still a bit concerned that the motor doesn't "fill" the frame fully. Tomorrow I am going to fit the front fairing subframe and attach the side covers to see if they close the gap.
Otherwise, it's looking like a supercharger.............
Garry
Don't worry about "filling" the frame. Besides, superchargers don't work very well on two-strokes anyway.
- Suzuki 2-Strokes: '72 gt750
Explain to a rookie why this is? In my inexperience I expected turbochargers to cause problems due to increasing exhaust backpressure but superchargers, not restricting the exhaust, would work better in most scenarios. educate me please.rngdng wrote:Besides, superchargers don't work very well on two-strokes anyway.
Also cool update Garry. Have you any idea what type of supercharger you might use?
'72 GT750
The main thing i could think of the supercharger creating a problem would be with the bottom end seals , they are not designed to retain much psi , i know even when doing a leak down test it is suggested to use not much pressure more pressure than 5~6 psi . But with most things .. if there is a will there is a way . Trains use superchargers on there 2 stroke diesels .
yes, that makes sense. It would apply to any type of FI then, not just superchargers.
Weren't some of the 2 stroke Detroit diesels supercharged?
'72 GT750
- garry55
guys - the supercharger comment was a reference to comments made earlier in the thread - I think SuzukiDave and TZR made the same observation in fun
The gap is as it is and will stay that way. I did notice that on the other side of the motor, the thermostat housing adds height to the head and fills most of the gap - maybe I should graft a false housing onto the left side?
Garry
I see, I didn't realize the comment was in jest. Carry on with the awesome updates!
'72 GT750
I think that the gap will look terrible. Maybe time to cut up the frame and raise the motor and maybe lower the tank and seat at the same time....
- garry55
you and your ideas - I am still trying to build the stacked gearbox you suggested a while ago...........
Garry
How is that coming along? Shorter motor would allow you to move the swingarm pivot forwards and fit a longer swingarm.
Fitting a supercharger would be easier. Keep having fun.
- garry55
been struggling to find a home for the battery, as it's usual place has been taken by the 2-stroke oil tank. But tonight, I had a Eureka moment, so it was out with the marker pen, drill and files..........
just a bit of cutting and grinding to do on the underside of the swing arm to get the battery box to sit flush
Garry
Put a pair of false breasts in the gap.
No one will notice that there should be anything else there - or not.
Less setting up than forced induction and won't affect the intake suction.
- garry55
the battery box, finished at last..........
Garry
