Hello Gents
Work on the 74 T500 coming along had inner seals done new Pistons,David Higgs making some nice pipes for me. Front brakes don't work that great, have the organic shoes turned on lathe came out nice drum super smooth tried roughing it up but hard as rock. The arms on linkage look good but just won't bite! Wheel built so I can't skim the drum.
Thanks!
T500 front brakes
- Country: United States
- Suzuki 2-Strokes: RD400 T500 Titan GT550
Re: T500 front brakes
That's the best time to skim a drum, it won't distort when trued then - any movement has already happened. You just need a bigger lathe which will be available, just not very often. Look in the bike mags for drum skimming, or even big engineering works. The drum inner doesn't need to be rough, a quick rub with scotchbrite or VERY fine emery to remove a glaze is enough.RossB wrote:Hello Gents
Thanks!
Loosen the arm between the two actuators and pull/operate the shoe with the cable arm with your thumb so the shoe is in contact with the drum. Now while holding it like that, turn the adjuster so that the second actuator starts to move. Keep your thumb on the first actuator and you will feel it start to push back as the second shoe comes into contact with the drum. Just back off a tad and tighten the lock nuts. Job done.
The brake was never fantastic in the first place, but was 'ok'. If you want better brakes, better fit a 4ls from an early kettle/550 or a disc upgrade.
Alan
Thanks will give it a try have a nice holiday!
Was surprised at how much improvement you get the first time I lubed up the drum brake system.
Properly lubed brake cable.
A bit of grease on the brake cam shaft. I lube the brake panel & insert the brake cam so any excess is on the outside & is easily cleaned up.
A smidgen of grease on the brake lever.
