http://www.pinkpossum.com/GT750/Oilpump.htm
The pump adjustment also depends on the type of carb.
The following are from the GT750 service manual.
GT750 oil pump output spec:
![Image](http://i1143.photobucket.com/albums/n623/jabcb/GT750_OilPump_Spec_zpsm2pt2tdl.jpg)
Early-model (72-73) GT750 oil pump adjustment with throttle open as shown:
![Image](http://i1143.photobucket.com/albums/n623/jabcb/GT750_OilPump_72-73_Adjustment_zpsax11d53j.jpg)
Late-model (74-77) GT750 oil pump adjustment with throttle closed:
![Image](http://i1143.photobucket.com/albums/n623/jabcb/GT750_OilPump_74-77_Adjustment_zpsitgzdsx6.jpg)
If you look closely at the two different actuator/lever arms designs, you can see the adjustment alignment marks are in different locations. The arms may also have different effective lengths.
Now for my issue:
I have a 75 GT750 with actuator/lever arm for the CV carbs but I have early-model carbs.
The arm has been modified to work with the early-model throttle cable.
I adjusted the arm per the late-model technique with the throttle closed.
Alternatively, I could switch out the arm but so far I haven’t found an early-model arm.
Question:
Am I done or do I need to find an early-model arm?
Also, it would be useful to see pics of the oil pump settings with the throttle closed & fully open for a stock early-model GT750.
