oil tank outlet
jasper
oil tank outlet
Post by jasper »
Hey guys.
I need to get the 'bowl' back on my 70' T500 oil tank outlet. How do you keep the pin in the cylinder while screwing the bowl on?
Do I need to take the whole thing off and install it upside down?
jasper
Re: oil tank outlet
Post by jasper »
Would it help if I posted a picture?
The pin is shorter the bowl, so if I insert it into the top half, (screwed into the oil tank) it falls out before I can get the bowl back on. Does the pin kind of float in the oil once filled? It doesn't make a lot of sense to me.
Re: oil tank outlet
I think we need some pictures.....I for one don't understand your problem?
jasper
Re: oil tank outlet
Post by jasper »
I tried to post a pic from my phone but it was too heavy.
I took off the top half of the outlet that threads directly onto the oil tank. The pin drives right into the oil tank filter. If I place the pin into the filter, then screw on the whole outlet,(dry) and tap it, the pin will fall into the bowl.
So my problem is that I am not sure how the pin stays put once everything is connected and oil is added. I'm concerned that adding oil to the assembled tank/outlet will drive the pin into the bowl.
Does that make more sense?
Pete O'Dell
Country: uk
Suzuki 2-Strokes: T500X2 GT500 GS750 GS500/4 KAWASAKI A1 GT250
Re: oil tank outlet
Post by Pete O'Dell »
I do 500 suzuki's for a living chap, and I am baffled at what your asking you need to upload pics is the filter in place?
jasper
Re: oil tank outlet
Post by jasper »
Yes the filter is in place.
Is this magnetic pin part of the filter? That would make more sense.
Re: oil tank outlet
Is this sort of what you have ? Do you actually have all of the parts ? That seal - item 13 - holds the filter tube (item 15) in place when its all bolted together. 14 is the cup seal. 8)
jasper
Re: oil tank outlet
Post by jasper »
http://i739.photobucket.com/albums/xx33 ... G_0999.jpg" onclick="window.open(this.href);return false;"
Pete O'Dell
Country: uk
Re: oil tank outlet
that aint part of the tank outlet chap, actually looks like a bearing retaining pin
jasper
Re: oil tank outlet
Post by jasper »
How weird is that?
I have never had the outlet apart so I know I didn't put it in there, and it fits perfectly all he way up into the filter. If it wasn't meant to be you would think it would restrict oil flow. I guess I wont be putting it back in.
Thanks!
