550/380 Gauges: Can someone explain this ?
Recently, I was cleaning up and servicing my gauges when I took notice of 2 holes that appear at the top of the mounting bracket. These holes have no apparent function. Nor do any fiches explain what they may have been used for. Does anyone have an idea ? I am pointing at the one of the two holes with an ink pen. They are both located horizontally from one another at the top.
Re: 550/380 Gauges: Can someone explain this ?
Is there meant to be a rubber cushion in there?
IIRC, they hold the two top bulb holders into the clocks.
I'll have a look tomorrow if you need further info. I'll get a pic.
titan performance wrote:Is there meant to be a rubber cushion in there?
I don't think so. This fiche shows all of the rubber cushions that I have installed. Doesn't show any inserted in the holes that I pointed out.
Alan H wrote:IIRC, they hold the two top bulb holders into the clocks.
I'd have to see that pic.
CBWELLS
Suzuki 2-Strokes: Honda-350, SUZUKI GT550 x2, GS850, 92 VMAX,
Post by CBWELLS »
That bracket may be used on more than one bike. They may be used in a different application.....but that's just a guess.
There y'go. They are bulb holder holders.
gt-keith
Suzuki 2-Strokes: GT380 & GSF650 Bandit
Post by gt-keith »
And drilled for lightness.
Thought of everything back in the day. :lol:
Hey that's an idea! I'll drill lots of holes in the 3 into 4 on the GT550 and save weight. Thanks!!
Will the carb jets be OK or will I have to fit different ones? :wth:
Sorry to disagree but I don't think they're bulb holders. The bulbs are held well in the clocks via their rubber grommet things. The bracket does press those bulb holders home but they are not attached to the bracket. I just dismantled my 380 clocks two days ago.
I too have noticed those 'redundant' holes (LMAB 380 bracket is same part number as LMAB 550, 34950-33120). And why is one piece with a hole in wider than the other? I also guess they fit a different bike which I believe includes T/GT500?
http://webcache.googleusercontent.com/s ... 4950-33120" onclick="window.open(this.href);return false;
The pic I took was on a 550J so maybe on that model they do hold the two bulbs in. They seem to on mine.
On the later models there are more bulbs so maybe they realised they held in on their own? Dunno?
Alan H. I think you may be on to something about that upraised section pressing against the grommet to perhaps aid in keeping them in place. But, that point you made. Which was good, still doesn't give an explanation for the holes.
Suzuki put those holes there so everyone would scratch their heads and wonder WTF :?
Well, it worked then :-)
Ah. WTF!
I did wonder WTF they were really for, so that must be it then. :wth:
