Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Sat Feb 22, 2020 7:24 am
Post new topic Reply to topic  [ 384 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 26  Next
Author Message
 Post subject: Re: XR11/73
PostPosted: Fri Jan 10, 2014 9:45 am
Offline
Think of it as a twin with an extra cylinder tacked on the right side.
With the crankcases in the right place and drive chain aligned, the whole top half hangs out to the right. Therefore, if the cylinder is centralized, the bottom end will move to the left including the sprocket.
Top
 Profile
PostPosted: Fri Jan 10, 2014 9:54 am
Offline
Suzuki 2-Strokes: GT750 hybrids (x2) VJ23A RGV500 TS185 R250
right - having carefully positioned and chocked the frame in a position that affords the chain run 150mm clearance from the inner frame rib, the rear upper motor mount sits off-centre in the frame. But rudimentary measurements show that the mount is 450mm from the left frame casting and 250mm from the right.
In the grand scheme of things, I don't think this will have an adverse effect on the overall package. Do you, guys?
Dave - do you know, or can you check sometime for me, if your SRAD motor rear upper mount is central to your frame?
cheers !
_________________
Garry
I'm addicted to brake fluid, but I can stop anytime.
Top
 Profile
PostPosted: Fri Jan 10, 2014 9:55 am
Offline
yep - thats makes sense to me - thanks ! :D
_________________
Garry
Top
 Profile
PostPosted: Sat Jan 18, 2014 3:45 am
Offline
Hi Gerry , any updates ?
_________________
Top
 Profile
PostPosted: Sat Jan 18, 2014 5:58 am
Offline
World Superbike
Suzuki 2-Strokes: 2 x GT550s GT750, T200, TC200
Saw it yesterday. The man's mad!
When it's built though, it'll be a thing of beauty and wonder.
If he has time with all the other projects on the go!
Thanks for the coffee, natter and 'bits' Garry.
_________________
I realize that you believe that you understood what you thought I said.
But I'm quite certain that what you thought you understood wasn't what I actually meant.
Top
 Profile
PostPosted: Sun Jan 19, 2014 8:29 am
Offline
nothing exciting Dave - fabbed the new upper rear engine mounts, jigged the frame and motor to mark the mounting holes, drilled them then jig-fitted to frame to test for fit prior to welding. Work prevents me from dropping the frame off at my welders until week after next now - so slight delay in proceedings. Gives me time to ponder other potential problems - think I have solved the radiator location issue though, thanks to Kawasaki................ :oops:
A few pics..............
_________________
Garry
Top
 Profile
PostPosted: Sun Jan 19, 2014 8:41 am
Offline
To pass time, and move the project forwards, I have spent part of my last 2 night shifts at work grinding-off the remains of the front engine mounting castings and weld to tidy the frame. A bit of filing and rubbing with emery cloth and it will be a lot neater. And lighter ! :D
Look away now if you are of a nervous disposition - to clear the new rear motor mounts, I had to relieve some more surplus metal from the Kettle motor. Who needs an oil pump cover anyway? :wink:
Thats all for now, folks - stay tuned ! :wink:
_________________
Garry
Top
 Profile
PostPosted: Sun Jan 19, 2014 8:44 am
Offline
Good deal and hey parts are parts , i will use what ever brand part that works :up: i used a Honda radiator and gas tank on my Yellow GTX-R 8)
_________________
Top
 Profile
PostPosted: Sun Jan 19, 2014 8:47 am
Offline
I had to grind away the oil pump cover area on mine also to get it to fit :up: Image
_________________
Top
 Profile
PostPosted: Sun Jan 19, 2014 8:55 am
Offline
I will use a Suzuki part Dave - the idea came from reading about a Kawasaki race bike. Like the rest of the project - it may, or may not, work. But I've gotta give it a go................. :wink:
_________________
Garry
Top
 Profile
PostPosted: Sun Jan 19, 2014 8:59 am
Offline
Knowing that makes me feel a lot better!
They hang people for less over here........... :wink:
ps - what have you got in your oil pipes - blood? :)
_________________
Garry
Top
 Profile
PostPosted: Sun Jan 19, 2014 9:00 am
Offline
Oi !!
I'm not certified...................... yet........... :D
nice to meet you too, Alan. Conversation to continue at yours, sometime soon :clap:
_________________
Garry
Top
 Profile
PostPosted: Sun Jan 19, 2014 9:19 am
Offline
I sure know what ya mean .. its sad how many tried and didnt end up useing parts that i have :oops:
_________________
Top
 Profile
PostPosted: Sun Jan 19, 2014 9:31 am
Offline
I know coffee but whats " natter and 'bits " ?
_________________
Top
 Profile
PostPosted: Sun Jan 19, 2014 10:01 am
Offline
"natter" - strange local dialect for "conversation"
"bits" - GT750 / RE5 front fork set and a fuel tap I had lying around and didn't want.
_________________
Garry
Top
 Profile
Who is online
Users browsing this forum: No registered users and 8 guests
Jump to:
Suzuki2Strokes.com
