T350
alanr
T350
Post by alanr »
if I suspect my right oil seal is worn (because it smokes on the right side )what color smoke should I see.is it burning crank oil or two stroke oil.also after about 15 seconds running then turning off the left side header is to hot to touch but I can rest my hand on the right side.a friend said the right has a problem because the left should be that hot.any opinions welcome.
CB360T
TT250
T350guy
Suzuki 2-Strokes: 1977 GT 750
Re: T350
Post by T350guy »
How much oil are we talking?
If a deal is leaking causing trans fluid to pass thru then it will smoke.
Does it smoke even after a good run?
alanr
Re: T350
Post by alanr »
T350guy wrote:How much oil are we talking?
I havent taken it for a long run in case I do damage.when I am running round the block I am getting clouds of blue smoke from the right side.
CB360T
TT250
