I just bought a rebuild kit for my fuel petcock on my 74 Buffalo.
It finally arrived and I was pretty excited about getting rid of the small drip.
I took the petcock off, and apart, and found the provided gasket was too small
So I gave the petcock to the engineers at the office and they made a CAD drawing of the correct part size.
The CAD drawing was sent over to our in house production department and in less than 15 minutes, they made me the correct part.
If anybody needs one let me know.
74 buffalo petcock rebuild kit
- Suzuki 2-Strokes: 72 GT750, 74 GT750
1974 GT750
1971 VW Bus
1977 Scout II
1985 Cabriolet
I can't save them all, I'll just save as many as I can
1971 VW Bus
1977 Scout II
1985 Cabriolet
- oldjapanesebikes
Re: 74 buffalo petcock rebuild kit
I'm curious - what was the part number for the gasket you bought originally ? Suzuki still sells most of the petcock repair parts and there are two gaskets offered: 44376-31050 for early and then 44341-33150 for later, and I know they are different sizes, but I can't recall off the top of my head which was the larger one. The seal that normally causes the problem is not sold and is the small pintle o-ring but you can usually find something suitable at an industrial supply place.
44341-33150 should have been what you needed for your model at $1.63 from Suzuki if you are in the USA.
If you could design up and reproduce the diaphragm side of the petcock you would make lots of good friends
- oldjapanesebikes
+1 to that !Suzukidave wrote:If you could design up and reproduce the diaphragm side of the petcock you would make lots of good friends
