T500 questions
racerd14666
Country: usa
Suzuki 2-Strokes: t500, gt380
T500 questions
Post by racerd14666 »
so i just picked up a 74 t500 and after doing some reading on this site i got the no spark issue narrowed down, but the points are pretty worn and ones not closing completely and im not sure were to find them so i was wondering if i could swap a gt 550 ignition system in. and what are my options for front end swaps cus id like to run disc brakes preferable dual disk brakes in the front
Re: T500 questions
I think you will find that points are still available from Suzuki - about $20 in USD per set.
racerd14666
Country: usa
Re: T500 questions
i looked online (bike bandit, ebay and a few others) and called a local suzuki dealer and they said they were discontinued so i will have to keep looking, what about swapping a cdi ignition from a gs550 cus i have a parts bike that appears to have all the parts there but i dont know if they are a direct swap
malky
Suzuki 2-Strokes: GT750A T500K T500L GT500A GT185A RV125L COLLE
Re: T500 questions
Post by malky »
you cant swap the cdi unit from the gt500 as the end of the crankshaft is different - new points are always available on good ole ebay for not much cash and I always keep a couple of spare sets in the tool roll just in case.Fired my t500l up this morning and it fired right up after the third kick - last time I started it was last October these bikes are very fussy about points settings so you need to get them spot on.
Malky
Re: T500 questions
racerd14666 wrote:i looked online (bike bandit, ebay and a few others) and called a local suzuki dealer and they said they were discontinued
We are talking about part number 31440-15020 ? I've just checked four on-line parts listings and they all show the points as available as well as the condensers. Prices range from just under $20 in USD through to about $30. Bike Bandit has them for $24.68.
johnakay
I likes them jubblies
Suzuki 2-Strokes: bike
Re: T500 questions
Post by johnakay »
YEP THESE ARE STILL AVAILABLE.....
http://cgi.ebay.co.uk/SUZUKI-T500-T-500 ... 2a0eb47d83" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
http://cgi.ebay.co.uk/SUZUKI-T500-T90-G ... 53e718dae9" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
and this PRICE!
http://cgi.ebay.co.uk/Points-RHS-Suzuki ... 56436dc9a6" onclick="window.open(this.href);return false;
racerd14666
Country: usa
Re: T500 questions
i must have ben searching wrong cus i swear last time i checked the said discontinued but thats good news that they are not. is there any power loss when running pod filters vs stock air box?
Re: T500 questions
That's the sort of question for which there are many points of view - with this generation of 2 stroke engine design, I personally think a better question would be is there any gain ? And if not, then why bother other than for reasons' of esthetics, or possibly there not being any other choice due to original design parts no longer being available. I'm sure others will jump in ! 8)
wvc
Re: T500 questions
Post by wvc »
I personally prefer the stock airboxes on bikes. Keeps things simple. No need to go thru the hassle of rejetting, plus the airbox is what supports the carbs from the back side. If you do go with pod filters, buy good ones, unless you like repairing worn out top ends. The cheapy chrome chinese jobs don't filter very well. Get the UNI or K&N filters.
76 GT500 - restoration project in work
4 other 76 GT500's
1.5 GT550's
4 GT380's
5 T500's (72-75 models)
4 GT750's
Suzuki GT hoarder...and a bad case of OBD.....(old bike disease)
racerd14666
Country: usa
Re: T500 questions
the cost of sourcing parts is the main reason why im thinking about running pods, cus i need the manifold boots, the air box connecting boot and air filters. but if pods cause me to loose power i would pry just go with a stock setup
parksie
Suzuki 2-Strokes: Suzuki t500 69,71,73, Gt500 76
Re: T500 questions
Post by parksie »
It's a cow of a job trying to get the jetting right for a T500 using pods instead of the original filter.
1969 T500
1973 T500
1971 T500 (being restored)
1976 GT500 (being restored)
2012 Ninja 650
racerd14666
Country: usa
Re: T500 questions
but is there any gains once its jetted correctly?
Re: T500 questions
I ca't speak for the 500, but on my 550 there is no discernable difference - stock box or pods. I am running pods and chambers so re jeting was certainly required. Lots of guys add pods and don't change anything, but I would suggest going 1 size larger on the pilot jets. Pods seem to suck more air at low speeds, so the increase in pilot jets helps the situation.
