Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Sat Mar 23, 2019 5:31 am
Post new topic Reply to topic  [ 17 posts ]  Go to page 1, 2  Next
Author Message
PostPosted: Sun Nov 21, 2010 12:31 am
Offline
I've just started pulling bits off the GT to begin the big spruce up. However, I did go for a ride yesterday and was very impressed with the acceleration of the big girl - not as lumpy as they look :D
As I took the carbs off, it became very clear that the vacuum aspect of the petcock is not working. Petrol just kept coming out of all the lines. Is it possible to rectify this or do I need another petcock?
Thanks, Mike
_________________
72 GT750J
71 TS250R
71 H1A
Top
 Profile
PostPosted: Sun Nov 21, 2010 8:30 am
Offline
Country: canada
Bikes owned: m12 or50 a100 s32-2 s32-2 t250 gt250 t500r
the diaphragm is probably ok. just stuck, or fuel would be coming out the vacuum spigot as well. i vote for a rebuild. suzuki petcocks are a bit expensive and not correct (black). thailand petcocks are total garbage.
_________________
m12 or50 k10 a100
s32-2 s32-2 t250r
gt250 t500r gt550a
twin cobras in baskets
Top
 Profile WWW
PostPosted: Mon Nov 22, 2010 5:37 pm
Offline
Bikes owned: GT750(Jx3,L,M,A,B),T500
For the GT750J/K the internals of the pet cock diaphragms are the same as those used on Kawasaki '69 through '72 H1's and those bits are still available from your Kwack dealer. 8)
_________________
Top
 Profile WWW
PostPosted: Tue Nov 23, 2010 12:17 am
Offline
Thanks for that. Think I'll pull her apart and see what looks not so flash. Will check against the parts diagram - I've learned that P.O.'s don't always put everything back :(
_________________
72 GT750J
71 TS250R
71 H1A
Top
 Profile
PostPosted: Tue Nov 23, 2010 8:59 am
Offline
Bikes owned: GT550x2, GT750, GS1000
Probably all you need to replace is o-ring #26. Diaphragms tend to stick to adjacent parts but can be easily separated with a DULL razor blade.
_________________
Top
 Profile
PostPosted: Tue Nov 23, 2010 11:37 am
Offline
Thanks great info!! Do you have the part number for part #24
Top
 Profile
PostPosted: Tue Nov 23, 2010 2:53 pm
Offline
Just take a look at the fiches here for part numbers. Availability will vary by country so you may have to do some searching to find a dealer than can supply what you need. 8)
_________________
Top
 Profile WWW
PostPosted: Thu Nov 25, 2010 10:17 pm
Offline
If the seat where the #26 o ring sits is corroded you can clean it with a q-tip and some polish so it doesn't have that infernal "slow drip".
_________________
So many Projects - So little time
Top
 Profile
PostPosted: Fri Nov 26, 2010 6:30 am
Offline
Depends on how deep the corrosion is. I cleaned up mine with a pencil eraser and some rouge. Lightly clamp the body in a vice with the seal surface facing up. Roughly shape rhe eraser to the taper. Apply some compound to the eraser and spin the pencil with your palms.
Mine does not leak which makes removing the tank a breeze.
_________________
Top
 Profile
PostPosted: Thu Feb 17, 2011 9:20 am
Offline
Is that small O ring still available? I have two petcocks with small hard O rings that broke up when I tried to pry them off.
Mine is a 74
Top
 Profile
PostPosted: Thu Feb 17, 2011 12:57 pm
Offline
I went into a seals and services outfit here in town that Uncle Rick suggested, and matched up some viton o-rings that seem to work fine. HVC offers the small o-ring also, but only as a part of a kit.
_________________
Top
 Profile WWW
PostPosted: Thu Feb 17, 2011 3:50 pm
Offline
Country: CANADA
Bikes owned: GT550A, GSF1200SK6 currently
Another good refurbishing device for the pintle seat is an unused chopstick from your favourite Oriental takeout place. A little work with a sharp knife so the chopstick end matches the taper of the pintle seat
and you can whirl it back and forth between your palms to polish the seat just like lapping a valve with a valve seating stick.
If the seat has visible corrosion pockets in it, you might want to try the same trick with a little extra fine valve lapping compound on the chopstick......but don't overdo it. Five or six rotations of the chopstick and then wipe the seat clean and check it. Repeat as necessary.
_________________
GT550A Mint & Original
MBD Sufferer
Top
 Profile
PostPosted: Thu Feb 17, 2011 5:08 pm
Offline
I have an HVC set and that O ring is a couple of sizes too large for4 some reason. I'll try the local auto store in the morning
Top
 Profile
PostPosted: Fri Feb 18, 2011 10:08 pm
Offline
This IS the real me!!!
If you can't find one of the regular Black O-rings that you need see if they sell Green Air Conditioning Orings.They come in Strange Sizes and are Gas resistant. :up:
_________________
Hang me from the Tree of Shame.Damn! I forgot the Rope.
Top
 Profile
PostPosted: Sat Feb 19, 2011 6:00 pm
Offline
Jug you wont find an A/C line o-ring in that size, not even a high side o-ring is that small. You would have to size it at an o-ring store or get an HVC kit.
_________________
Top
 Profile WWW
Who is online
Users browsing this forum: No registered users and 16 guests
Search for:
Jump to:
Suzuki2Strokes.com
