trans oil from pee hole in water pump housing
- T350guy
When the Gt 750 is running say whether it's a 10 mile or 50 mile it does NOT leak oil..bone dry underneath.
I'll let it sit say for 1/2 hour still dry..1 hr still dry.maybe 2 hrs later a very small drip..then over night a small puddle which is wiped up with a rag.
So why doesn't it leak while running , is it a vacuum thing when cooling down that cause the oil to be sucked past the seal?
No coolant in the oil or oil in the coolant
I have a new water pump ready to go in if needed.
Re: trans oil from pee hole in water pump housing
That's an odd one. Transmission has no oil pump but I wonder if the oil level is effectively lower when it's running as oil wraps around the shafts and gears. As it sits, that oils slowly but inexorably falls back to the "sump" and starts to seep out.
That suggests that the oil seal is probably in need of replacement and the shaft may also be scored.
I would replace or rebuild the pump and check the oil level while you are there
- Suzuki 2-Strokes: GT750
Richard, Would you rebuild mine too while you're at it?tz375 wrote:I would replace or rebuild the pump
I wonder if the coolant is heating the impeller shaft enough to expand it toward the case while the engine's running, temporarily stopping the leak? Either way I agree, that seal seems to be the prime suspect.
Mine's been dribbling a little oil too so I'll have to replace or have it rebuilt in the very near future. If I can get away from my other projects long enough that is.
Looks like the pump price has been elevated to $205 on Alphasports. Is rebuilding them becoming more cost effective?
1974 Suzuki Nomad 340
That is what I do but I go through a lot of parts to make one good pump. It's amazing how worn/rusty/scored, damaged some shafts are.
I recently inherited a small collection of stripped pumps and I'd guess that 75% of the parts ended up in the trash or re-cycling bin. I think I kept 1 shaft and 3 bodies out of 4 pumps, so technically that's closer to 25%.
$205 for a new pump sounds reasonable to me. Especially if you consider the carbie boots on the 380 and 550 are $40 per, and you need 6!
Hey Chris,Coyote wrote:$205 for a new pump sounds reasonable to me. Especially if you consider the carbie boots on the 380 and 550 are $40 per, and you need 6!
Yeah I agree that's not too bad except when you consider they were $134 not too long ago.
Richard, I heard you won the bid on that Dansville auction. Hope you're making good use of your new hoard.tz375 wrote:I recently inherited a small collection of stripped pumps
OK, end hijack,
Josh
Dansville, what and where was that and what was being sold?
No. I bought a couple of bikes from John Fry and they came with a few spares that I am sorting through. John had collected a few GTs and I think he also had some that came from Gordon Lamb. That's what I'm sorting through and so far a truck load has gone to re-cycling. I'm working through the rest slowly.
When I started rebuilding the motor is one of the bikes, that was the time to sort through my water pumps plus one I had been given plus the new ones and there were lots of damaged shafts and old bearings that are now being melted down and made into something useful.
Gordon Lamb? That goes back a ways TZ. Met Gordon once when he stopped by to pick up a scrap 400 for Lane. At the time he also had a GT380 on his trailer that he was delivering to Adam in Arkansas.I think he also had some that came from Gordon Lamb.
The drilled rotors on my 550 cafe came from Gordon.
John lived in Dansville. That was my attempt at being subtle, although maybe it was a little too coded. I know there was at least one other 'bid on that auction'tz375 wrote:Dansville, what and where was that and what was being sold?
Duh....
Can't believe I missed that.
Hey you. We don't do subtle.....
The (77 B) cafe is just a little worn out and will need a fair amount of work to bring it back to its prime, and while it's apart I may make some changes to perk it up a little. JF and GL seemed to like gray ghosts, but I need bright colors. I'm partial to white or gold wheels, red or silver frames and black engines so anything is possible. JF was very generous and genuine in our discussions/negotiations. He just had too much stuff..
I have almost finished sinking a ton of hours and dollars into the red bike and it is putting up a good fight but I like to think that I'm winning. Today I had it running sweetly and it picks up revs nicely too.
It now has GS mag style wheels with drum rear, new tires and chain and the electrics are completely reworked. Motor was stripped to the last component and rebuilt with new pistons etc. It has Newtronics (off the Cafe) and an ignition circuit relay and lots of new connectors and terminals and other components. It's all shiny and clean and not looking over restored which I don't go for. This one will look original and clean and should run nicely. Just the seat and tank to finish and then road test it. - I hope....
You've been busy! It sounds like they went to the right person. I always thought John's gray café was an L. Maybe the engine was from a '74? I'm not admitting defeat just yet.
Will you be keeping these orphans for your collection or are they getting new homes?
76 Red will go to a new home in January if everything works out according to plan and we know how often that happens right?
Gray Cafe is a number matching 77 with the correct B style V crankcases. I can't ride all the projects I had before this double wide trailer load was dragged back to IL.
But,this lot gives me choices as to what to build and how it will look etc. That way i get to try every shape of GT that I can think of. Traditional Cafe racer through to modern looking sport bike and maybe even drag racer in the mold of those crazy superstreet type bikes that run 8.8 second quarter miles. This will never do that but it might look like it could..
- fartymarty
- Suzuki 2-Strokes: Past GT550, curr '76 GT750
O ye of little faith.tz375 wrote:76 Red will go to a new home in January if everything works out according to plan and we know how often that happens right?
