1972 gt750 muffler cone removal
kiwi
Country: New Zealand
Suzuki 2-Strokes: gt750j, m109r, zzr1200, t350, ts250, cb500, g
Post by kiwi »
hi guys,can anybody tell me how to remove the muffler cones from exhaust on 72 gt750,they seem pretty solid and cant find a screw or anything,do you just tap them out,any help appreciated
Re: 1972 gt750 muffler cone removal
They are a twist and lock design and there should be a retainer bolt - after removing that bolt (on the underside) if you push on the end of the cone and at the same time give them a twist (I forget which way, but try going left and see what happens) they should eventually come off. A hot air gun may speed up the process, but try not to damage the rubber seal. 8)
artsmokes
Suzuki 2-Strokes: 1972 GT750J 87 LTF230
Post by artsmokes »
Just had mine off of my 72 GT750J Just loosen the Phillips screw through the hole in the cone and twist counterclockwise. Take the screw out to remove baffle
