should the t500 petcock shut fuel flow when not running?
Repeater
Suzuki 2-Strokes: 1974 T500 & 2007 GXS-R 600
Post by Repeater »
When my fuel line is disconnected from the carbs fuel keeps flowing.
I have a spare but would rather not use it yet.
Re: should the t500 petcock shut fuel flow when not running?
Yes it should stop. It should only run when in 'Pri' - or prime position.
'On' and 'Res' should be controlled by the diaphragm which operated on pulses from the engine. Change it NOW before one of the carb floats leaks and allows fuel to get into the engine and cause a possible hydraulic lock damaging it.
Alan H wrote:Yes it should stop....Change it NOW before one of the carb floats leaks and allows fuel to get into the engine and cause a possible hydraulic lock damaging it.
+1 to this - either replace or repair it as it gets really expensive in a hurry otherwise. 8)
Repeater
Post by Repeater »
Thanks for the reply. I'll change it today.
