LH crank seal? 74 GT 750
Posted: Sat Aug 10, 2013 3:06 pm
I installed my GOOD Octopus oil line and go for a test ride.( been having heavy smoke issues on left side )
The left side bellowed smoke which slowly dissipated somewhat after a few miles.
After about 10 miles both sides were running not bad, still slightly smoking but OK.
Stop to see a friend for a few minutes and leave with smoke bellowing out again..2 miles later it kinda clears but still smoking more than usual.
Once home I checked the trans oil and discovered it was down about a quart and a half.
There is NO crank blow by at all.
Like most 2 strokes will replacing the RH outer crank seal solve this? Edit ..Looks like it won't
I know the Gentleman that rebuilt the motor and he would have used New Seals so this has me puzzled.
Should note when home I looked at the exhaust and the Left side still smokes slightly more than the rest..weird
Pulled the 3 plugs and all running a very nice tan and my Wife noted it wasn't smoking when coming down the road to the house.
Edit
It would seem ALL new seals were installed according to the previous owner.
Edit
Just fired the bike up and the LH exhaust is smoking excessive while the RH and Middle are clean.
Still trying to find a good photo of the starter clutch housing to see if Oil is in that Housing and if so it maybe be the LH crank seal..cause really what else would cause this?
Edit
Edit
