1971 T500 Electrical Question
Posted: Mon Feb 11, 2013 1:51 am
Hi folks, just in the final stages of a T500 restoration, thanks to all for the excellent info on this forum, it has helped me immensely however I have a problem that I need some help with.
So I was ready to start the T500 on the weekend, primed the oil lines, set the timing, points etc and when I was checking spark found that I was getting left and right spark to right spark plug and nothing to the left. I started to check everything and it had me stumped. I had replaced the main loom with a new oem one so started to work my way through the original electrical, there is quite a bit of info on this site regarding this and I kept getting the correct readings. The last thing I checked was the left handlebar switches, I disconnected these at the plug in the headlight shell and found I now had spark at both plugs. At this point I couldn't help myself and had to try and fire her up so connected a small petrol container I use when I have the tank off my bikes and she started after about half a dozen kicks, nice, spent a bit of time, priming oil pump, tuning the carbs, adjusting timing and it was everything I hoped for with my first 2 stroke...noisy & smelly.
So back to the wiring fault, does anyone have any idea what could cause both sparks to one side when the left handlebar loom is plugged in? Regards Richard.
