Tach cable removal
Posted: Tue Dec 18, 2012 7:17 am
by scout
Is there a retaining device of some sort behind the ignition holding the cable into the case? Mine will not pull out. It looks somewhat corroded.
Also, whats a practicle way to remove loose carbon from the pipes after the baffles are out? Just keep shaking?
Re: Tach cable removal
Posted: Tue Dec 18, 2012 5:38 pm
by Suzukidave
Not sure about the cable but to help get the pipes clean .. block the engine end opening and stand them up and fill with a strong mixture of something like simple green or purple cleaner .. one of those good degreasers . I have also read of guys taking the pipes to a shop and paying them to set them in there hot soak tank .
Posted: Wed Dec 19, 2012 4:34 am
by csd4t
My tacho cable was corroded solid so had to resort to the Dremel to split the outer threaded part.
Posted: Wed Dec 19, 2012 5:28 am
by scout
The retaining cap spins off, but the drive part of the cable wont pull out.
Posted: Wed Dec 19, 2012 7:59 am
by Coyote
No retainer on a 550. Do you have the cable off the tach?
Posted: Thu Dec 20, 2012 12:37 am
by scout
No, I do not......
Posted: Fri Jan 04, 2013 8:40 pm
by scout
Soaked it with penatrating oil and after a couple days it pulled out with a pliers. Nothing holding it in except rust.
Posted: Fri Jan 04, 2013 9:50 pm
by pearljam724
For the carbon. Use a long flexible piece of metal on the header end. Problem is, you can't access the longer portion of the pipes with a rod because of the bulkhead like chambers. And thats where all the carbon would rest. I too would like a better way. You could put round rubber stops used for plumbing at the header ends and fill all the pipes with a degreaser. Like, suggested earlier. But, I think that would take at least a couple of gallons. Unless, someone didn't mind recycling from one pipe to the next.
