gt380 un-even smoke. ?? console me.
zk0ot
Country: usa
Suzuki 2-Strokes: 1
Post by zk0ot »
recently put a set of 3 to 3 chambers on. and havent driven more than around the block. but after raising the needle (2nd to bottom) i started it up and noticed the left chamber puff pretty good. and not really anything from the 2 on the right. all the pipes are hot.
havent really warmed it up yet... i am without the centerstand now i read that maybe leaning to the left maybe cuase an oil rush to that side while standing a few days...
all the lines are red as well...
Re: gt380 un-even smoke. ?? console me.
It's probably OK but to be sure, you could remove the pump and use a syringe to fill the lines with gold oil and replace the pump and run it. That way you can see if teh Gold is replaced by red and if so all is fine
zk0ot
Country: usa
Suzuki 2-Strokes: 1
Post by zk0ot »
sounds easy enough... i left it on the rear stand yesterday ill drive it around today and see if anything changed.
