GT550A Charging Troubles
Posted: Sun May 27, 2012 6:48 pm
I recently added a GT550A to my garage. Bike has about 13,000 miles and is in VGC overall. After a recent 2-hour run on a warm day, I noted that the bike almost didn't want to restart, even though I had put in a brand new, freshly-charged battery. Also noticed that the alternator cover was too hot to touch - much hotter than the engine. I got a meat thermometer from the kitchen. The ram air cover measured about 115 degrees F. while the alt. cover was over 135 degrees. After a weekend of testing stuff, here is what I found:
Charging voltage is 13.5-14.5 at 3-4000 rpm when engine is cold. Voltage drops to 12-12.5 when engine is hot. Charging system will charge at up to 10 amps when cold, but only -1 to 1.5 amps when hot.
Field coil and stator coil resistance and continuity checks are all factory when cold or hot. VR checks out. Rectifier checks out fine cold, but some of the diodes allowed current flow in both directions when rec. was hot. Readings returned to normal as soon as rectifier cooled down.
Checked all wiring related to battery, fuse, ignition switch, charging etc. All wires and connectors are clean and solid and tight. Checked each wire for high resistance. Checked load on the battery (lights, field coil, ignition coil, recifier, VR, etc.) Each load seems accurate and appropriate. Loads are consistent - no change whether bike is hot or cold. Total draw is about 9.5 amps. The only non-stock loads on the system - H4 headlamp (about 10 watts over stock) and two additional tailights (8 watts each) I performed all of the tests with the extra taillights unplugged and it didn't seem to make a difference. I even did the hot tests with the lights off and the system still couldn't charge.)
I performed the Suzuki factory manual tests with the bike load off line, and the VR unplugged. Both cold and hot, the alternator put out the specified volts and a good bit more.
I replaced the faulty rectifier and the VR with brand new single rec/reg unit from Electrosports this weekend. Rain let up today so I could test ride. Cold, the voltage is 13.5-14.5 depending on rpm, lights on or off. Hot, voltage is 12- 12.5 with the lights on, 13-13.5 with the lights off. Alternator cover is not as hot as before. So the new Rec/Reg helped, but not enough.
Am I ready for a new alternator? Any other suggestions?
Thanks!
Thanks!
