GT750 Cylinder head and Cylinder block Identification
Posted: Wed Mar 21, 2012 11:04 pm
by jaycee69
Hey does anyone have a link to a site that has the differences in the cylinders and cylinder heads from year to year?
I found one a while ago but cant seem to relocate it.
Regards,
Justin
Re: GT750 Cylinder head and Cylinder block Identification
Posted: Wed Mar 21, 2012 11:36 pm
by oldjapanesebikes
I happen to know one ! :D :D Take a look here. 8)
Posted: Thu Mar 22, 2012 9:08 am
by jaycee69
Lol isnt that your site? and i did find the info i needed. turns out 76 and 77 barrels and cylinder heads are the same. its funny i have poured over that site a bunch of times and missed that section. oh well! It is also nice to see another Two stroke fan in Canada!
Regards, Justin
Posted: Thu Mar 22, 2012 11:56 am
by oldjapanesebikes
There's a load of us up here - the smoke is handy in the summer as it keeps the mozzies and black flies down ! :D What part of the country are you in ?
Posted: Thu Mar 22, 2012 10:29 pm
by Suzukidave
Without looking at Ian's site i believe there are 4 different cylinders and maybe 3 different heads not counting the 2 piece head ?
Posted: Fri Mar 23, 2012 8:31 am
by oldjapanesebikes
Suzukidave wrote:Without looking at Ian's site i believe there are 4 different cylinders and maybe 3 different heads not counting the 2 piece head ?
That matches my count Dave 8)
Correction: four heads plus the split head, so five total.
Posted: Fri Mar 23, 2012 10:31 am
by jaycee69
I am In Nelson, British Columbia. and what years were the heads different? 72-73,74-75, and 76-77? and was there any benefit to the Split head design?
Posted: Fri Mar 23, 2012 2:04 pm
by oldjapanesebikes
jaycee69 wrote:I am In Nelson, British Columbia. and what years were the heads different? 72-73,74-75, and 76-77? and was there any benefit to the Split head design?
Nelson - not so far from here, and I know of a couple of GT750's living in Vernon which is (sort of) in your area !
There were three head designs in the first two years of production, including the split head, and the 'why a split head' question is as yet unanswered. Gunnar wrote a section on it which can be found here.. The head looked the same from the late 'K' onwards with a small change happening in 1975 which in theory boosted the compression ratio. Take a look at service bulletin GT-7 found here. I say in theory as you also needed to use the thin head gasket to get the full effect - I suspect the thicker after market gaskets pretty much negate the value of this so for all intents its a wash. If you just want to ride it - I wouldn't worry about the differences. If you want to play, then do some searches on the board as there are lots of things you can do to rapidly deplete your bank account ! :D
