Smooth shifting but smokes like crazy, need advice..
Posted: Sat Mar 17, 2012 7:11 pm
Hey guys,
My 1970 T500. It had 11200 miles when I bought it - runs pretty good except when it exceeds 70 mph, then it starts to hesitate - I have 11700 miles on it now.
The guy I bought it from said he changed the transmission oil but I did not like the way it shifted, especially in 4 and 5. It was not smooth, so I decided to change the transmission oil at 11700 miles. I bought Belray gearsaver 80w. I drained the oil, all three plugs, looks like 10w40 came out, but not very much, only 500cc, i measured it, not good. I added the required 1400cc based on the Suzuki Forum threads below. Shifts great but started smoking like a bandit. Can you make any suggestions. I noted that some guys mentioned a leak down test, is this something I need to do, to see if the crank seals are bad? Any advice is appreciated.
LexPaul
viewtopic.php?f=2&t=5820&p=114578&hilit ... il#p114578" onclick="window.open(this.href);return false;
http://www.vjmog.com/ftopict-8630-t500. ... mission+oi" onclick="window.open(this.href);return false;
LexPaul
