HELP! Clutch Push Rod
Posted: Fri Nov 04, 2011 11:49 pm
by kadavenport
I bought a GT550 a couple of months ago. The other day my chain broke tearing up the side case and the clutch push rod. I was able to source parts, but when I tried to install the push rod, it only went into the seal about half to three quarters an inch. Could the other push rod be stuck? I removed the clutch basket prior to tying to install the push rod. Any help would be greatly appreciated!
Thanks.
Re: HELP! Clutch Push Rod
Posted: Sat Nov 05, 2011 3:41 pm
by Coyote
The other rod may have bent slightly from the impact. I assume you are putting the new rod in from the left. On the clutch side, can you see the other rod? Can you pull it out? If you can't see it it's jammed in there. Go to the hardware store and buy a slightly smaller rod and see if you can drive it out. Don't get crazy though. Are you sure the seal is square?
Posted: Sat Nov 05, 2011 7:03 pm
by kadavenport
It looks like the seal is square. I can't see it from the clutch side, and tried the smaller rod approach as well. Its not budging. I'm thinking this means splitting the cases and possible getting some replacement trans parts. Is that my only option? I guess if i go that route is there any upgrades I should do while I'm in there? Also, are gasket kits still readily available, and do they come with all gaskets and O-rings? I know some of the seals are no longer available. Thanks for the help.
Posted: Mon Nov 14, 2011 3:23 pm
by Coyote
Did you ever get it out?
Posted: Fri Nov 25, 2011 11:12 pm
by kadavenport
No I wasn't able to get it out, I went ahead and bought a seal kit, a new clutch push rod, push rod actuator, and transmission. Now I just need to find time to split the cases.
Posted: Sun Nov 27, 2011 4:53 pm
by Coyote
New chain and sprockets of course. Don't cheap out on the chain. You see how much can happen when they break.
Posted: Mon Nov 28, 2011 7:08 pm
by kadavenport
Yeah lesson learned. Bout to kick off a search for sprocket sizes on the site, thinking about going up a tooth on the rear for some extra low end grunt.
