Suzuki T500 Kick Start Shaft Oil Seal Replacement
ericsattic
Suzuki 2-Strokes: Now T500, previous TS185, GS750, GS1000
Post by ericsattic »
Can anyone give me some basic tips related to removing and replacing the kick start shaft oil seal for a T500 (located on left side of engine - can be seen after removing sprocket cover)? I have ordered the part. I do not think I have to split the cases to do this; so what is the best way to remove the old oil seal? And how about installation of a new one - any tips for installation that I should be aware of so that I do not damage the new seal?
1968 Suzuki T500 Cobra
1970 Suzuki T500 Mark III [rebuild project]
1970 Kawasaki 500 Mach III - H1
1975 Kawasaki 750 Mach IV - H2
1970 Yamaha R5 350
1984 Yamaha RZ350L [acquired September 2015]
MikGsxr
Re: Suzuki T500 Kick Start Shaft Oil Seal Replacement
Post by MikGsxr »
Bump for this, looks like I have the same problem? I have gearbox oil dripping out from under the sprocket cover when the bike is hot, it drips like a leaky tap.
Had a similar leak but not quite as bad on my T350. Was the gear shift seal -- its lower in the crankcase & is submerged in the tranny oil.
Sorry I can't help you on tips for replacing the seal. Had a local bike shop do the repair. He didn't charge much so it couldn't have involved doing much.
Have no leaks now that he replaced the shifter seal.
MikGsxr, your leak might also be from the shifter seal.
MikGsxr
Post by MikGsxr »
awesome, thanks guys. i will take the cover off this week and see which part is actually leaking. is the shifter seal as easy to replace?
Fritz500
Post by Fritz500 »
Mik,
Check this series of photos out - should answer some of your concerns.
https://picasaweb.google.com/1174857257 ... 8413490034" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
I can assist if you want.
73 GT750 Ducati - 20%
72 T500J - 95%
09 Yam XVS950A
MikGsxr
Post by MikGsxr »
good pics Geoff, should be easy. I just emailed mcculoch for the parts, if they don't have them, will try fleabay.
will let you know,
regards
