Clutch removal suggestions, X-6
Posted: Sat May 21, 2011 6:19 am
by barko1
Looks like a 26mm nut that holds the clutch basket on, of course I don't have one
My manual says to use the special holder to keep the crank from moving, would an impact wrench work? I'd rather not remove the head right now, just the clutch
Thanks for any ideas.
Re: Clutch removal suggestions, X-6
Posted: Sat May 21, 2011 7:09 am
by Coyote
To lock the motor to remove the clutch nut, stuff a rag between the crank gear and primary gear. Reverse rag direction for tightening.
Posted: Sat May 21, 2011 4:08 pm
by barko1
Coyote wrote:To lock the motor to remove the clutch nut, stuff a rag between the crank gear and primary gear. Reverse rag direction for tightening.
Thanks!! That was easy. found a 27mm socket and pulled it off. 1 step down, 1000 to go
