No spark after rebuild - problem solved!
Posted: Sat Apr 09, 2011 6:30 pm
When I went out to start the bike this morning for the first time after the engine rebuild there was no spark. I've been checking things all day and at this point am just out of ideas. Advice/ideas welcome... please! Here's what I've checked/done:
- Initially I had spark on only the center point and spark plug. It seemed overly strong and erratic on the point.
- Replaced the condensers with the ones I had on before the rebuild (since I knew they worked when I took it all apart), cleaned the points, and sprayed electric cleaner on the entire area. Point gaps are good too.
- Rechecked, no spark on anything.
- Tested points wires all the way back to the coils with resistance tester - all good.
- Tested on/off switch and key switch - good.
- Followed positive wire from battery to key switch to coils. Measured 0 ohms resistance through each wire. With 12.7V in battery orange wires at coils were reading 11.0V. If I disconnected the voltage regulator I got 12.4V at the coils.
- Currently no spark on anything.
