T500 blinker switch
kall399
Country: Finland
Suzuki 2-Strokes: 1973 T500
T500 blinker switch
Post by kall399 »
Hello
The blinker switch in my T500 has always been on the vague side in terms of tactile feedback but it's gotten worse now.
So does anyone know of where I could possibly find a replacement switch to replace the internal switch without changing the whole switch body? Or has someone possibly replaced theirs with a commonly available slide switch
Re: T500 blinker switch
Ebay is your friend.
argo1974
Post by argo1974 »
I had the same problem on my T500K and replaced the whole unit with another one off a later T500, perhaps M or L model. Slide switch was updated to a more reliable lever switch on them. You barely notice the difference visually.
1x T500 Cobra (1968)
4x T500K (1973)
garncarz
Country: United States
Suzuki 2-Strokes: 1972 T500J
Post by garncarz »
Lots of corrosion/crap in your photo. Take the switch apart, contact cleaner, lube, resolder all the connections, reassemble?
kall399
Country: Finland
Post by kall399 »
argo1974 wrote: Tue Oct 22, 2024 7:56 pm I had the same problem on my T500K and replaced the whole unit with another one off a later T500, perhaps M or L model. Slide switch was updated to a more reliable lever switch on them. You barely notice the difference visually.
I have been looking for a good one but they seem to be for sale rarely or very expensive
kall399
Country: Finland
Post by kall399 »
garncarz wrote: Fri Oct 25, 2024 5:36 am Lots of corrosion/crap in your photo. Take the switch apart, contact cleaner, lube, resolder all the connections, reassemble?
The problem isn't really bad connections it's mechanical wear in the switch making it very sloppy
