‘74 GT550 needle valve and seat
Posted: Fri Jul 26, 2024 9:44 pm
by pgb123
Where can I source this in the US? Ganged carbs 341-11. I read somewhere that modern Mikuni valves should fit. Just can’t determine which.
Thanks in advance.
Re: ‘74 GT550 needle valve and seat
Posted: Sat Jul 27, 2024 4:26 am
Compare your needle valves to the info on https://www.jetsrus.com/needle_valve_fl ... ikuni.html
The size is stamped into the seat.
They are a common part pretty much available everywhere including Amazon, eBay, your like bike dealer, & Jets R US.
Posted: Sat Jul 27, 2024 9:20 am
by pgb123
Thanks so much. I came across that, but I’m still unsure how to determine which part is correct. The seats are marked 2.0.
Posted: Sat Jul 27, 2024 12:24 pm
by pgb123
I came across this site which sells aftermarket parts
https://motocomp-online.com/kawasaki/26 ... asaki.html
This leads me to believe the seat and valve for the GT550 are the same as the ones for Yamaha XS650 which are pretty accessible. Any thoughts?
Posted: Sun Jul 28, 2024 5:02 am
Looked at the GT550 needle valves listed on eBay.
They look like the Mikuni VM26/26 or possibly VM15/172.
Measure the thread OD. If 9mm then they are VM26/26. If 7mm then they are VM15/172.
Looked at my purchase history. Bought VM26/26-2.0 a bunch of times. Didn’t find a VM15/172 purchase.
Jets R US lists them as: (2.0) VM26/26 002-189
Typically they are listed as I have (- size): VM26/26-2.0
Some retailers discount the genuine Mikuni needle valves. The aftermarket equivalents are available for a good bit less.
Posted: Sun Jul 28, 2024 8:01 am
by pgb123
That is super helpful! Thank you. Any benefit/detriment to using 786-15005, the one with the viton tip?
