melted rubber boot
kawonda750
Country: canada
Suzuki 2-Strokes: 74 gt550, 88 Yamaha FZR400, 2019 Kaw Z900RS
melted rubber boot
Post by kawonda750 »
I finally pushed myself to start on the GT550 carbs. It seems that the lower rubber boots have deteriorated to the point where they are melted goo. I got them out with a few curses and very dirty gummy hands and thought that Varsol ( maybe some call them mineral spirits) would easily clean them off. Wrong.....
My hand cleaner got my hands reasonably clean and the Varsol did nothing. I will try carb cleaner and parts cleaner later. I can't use my pumice-based hand cleaner on the carb slides though.
Has anyone encountered this before ? Any cleaning suggestions?
kawonda750
Country: canada
Re: melted rubber boot
Well, I now know that carb cleaner gets it off with the help of a tooth brush. The bad part is it stinks and is very tedious so I can only do one slide set per day. :cry:
dollydog
Country: england
Post by dollydog »
horrible stuff mate, as i know from experience. unfortunately you'd answered your own question before i saw it. btw if you haven't got new boots, there's a bloke in holland that sells repro items and they don't melt in petrol vapour :D
p.s. that's just supposing he still sells them.
karl pa
Country: us
Suzuki 2-Strokes: GT
Post by karl pa »
kawonda750 wrote: Sun Dec 10, 2023 7:59 am Has anyone encountered this before ?
As far as I know, anyone with a 74 or newer GT380 or GT550 have encountered this. I replaced the boots on my 380B about 7 years ago and they have begun to melt again. They are still available from Suzuki, but I am afraid they won't last very long with today's fuel.
While you have the throttle arms off the shaft, check the arms around the keyway for cracks, I had 2 that were broken.
kawonda750
Country: canada
Interesting that this is common. I have both sets of boots. Since I am only a fair weather rider at this age, would I be fine to leave the boots off?
Or, do I just replace them every few years rather than wait for them to turn to this sticky mess? Encountering a whole new set of pitas and quirks with Suzukis as opposed to Kawis.
karl pa
Country: us
Post by karl pa »
I didn't replace the throttle arm boot (upper boot), they don't seem to be a problem, they also wouldn't matter if left off. The throttle lever boot (lower boot) seals the slide chamber, I know some say they leave off, but I am not sure what effect this would have on fuel mixture.
kawonda750
Country: canada
Thanks Karl. I guess I will put both on but keep a close eye on the lower ones so I don't have to go through this again. Also, my wife is mad at me for stinking the house out with carb cleaner. One of the disadvantages of having the garage attached to the house.
My bad......
kawonda750
Country: canada
I received genuine Suzuki lower boots with the bike but today I ordered another set from Legends in UK. They say that they are modern fuel resisant.
I'll find out in the spring....
kawonda750
Country: canada
Well, I finally got the goop off all 3 slides. Did an ultrasonic cleaning of the carbs and then carb cleaner and blew out the passages. I have a huge selection of new jets so will use them and re=assemble the carbs. I sent the wheels and new tires that I received with the bike out to be mounted. ( I hate changing tires) . Frame is cleaned up and while the wheels are off I installed new rear brake shoes. Now, it is hurry up and wait for the crank to come back from the rebuilder. He always takes months to get at it but he is one of the only games in the area so patience is necessary.
I will get at polishing the cases soon. I always end up looking like Al Jolson after time on the electric buffing wheels. It's a really good look though...
kawonda750
Country: canada
I set up the carbs yesterday. Instructions how to set up the carb control were sketchy in the Suzi service manual, Haynes and Suzuki triples book. As with the Kawasaki site, thanks to Dale, mraxl , for his resource site . The Mikuni carb manual was very good and I managed to get the synch and set up right. Well I hope anyway.
I received and installed the new lower boots that are modern gas resistant. Again, hopefully anyway. I still haven't heard from the guy installing the new tires so that will have to wait until after the holidays.
